How do Local channel numbers appear on Voom Receiver?
  • WELCOME TO THE NEW SERVER!
Harrypr
23
I am curious as to how local channel numbers appear on Voom receiver, by station number or by 3 digit number. Also do HD local broadcasts have a separate channel number than the same channel broadcasting a SD program? For example, I'm in Atlanta- ABC is channel 2, FOX is channel 5, UPN is 10, NBC is 11, WB is 36 and CBS is 46.... Thanks
They will appear as:
2-1
5-1
69-1
11-1
36-1
46-1
If your local broadcaster is sending the HD and SD signal through one channel that's how is going to show up in the VOOM PG. However, if there are sub-channels assigned to a particular channel, the sub-channels will also show. VOOM will map all the broadcasters channel according to how they are sending the signal. I have included two pics.
