how many transponders should I be connected to?
Lkr
1,792
I have AT250 and HD Ultimate and I'm connected to 46-47...is everyone else the same?
I'm not sure where you see how many TPs you are connected too, (I'm sure its in a menu somewhere). You likely see TPs even if you don't necessarily sub to all or any of the channels on that TP. It likely has more to do with which Sat Dishes you have in your setup. So if you see 110/119 & 61.5 then that might be X num of TPs, but if you have 110/119 & 129, that might be a different number of TPs, even with the same sub.
E* Link Removed from Voom.com
Problem with "Point Dish"
