How to dissemble the dp quad lnb
How to dissemble the dish pro quad lnb to find its components to make sure it works before installing
I'm curious about your current interest in everything DISH circa 2002. As far as your question, in 21 years as a retailer/installer, I've never disassembled an lnbf to determine if it was operational. Install it. If it doesn't work, swap it out. That said, other than a run of Dp lnbf's in the mid 2000's that had a high rate of heat related failures, they were very reliable.
Yeah I disassembled a DPP Twin LNB You pretty well have to destroy the plastic cover, then the unit is sealed, was able to open it up and it's just a circuit board and the feed horn, for all the hassle, it's just easier to repla e the entire LNB putting it back together probably won't make it weatherproof anymore
Reactions: TheKrell
