HR20-100 Audio sync problem
junianby
39
Uniontown, PA
Does anyone in the Pittsburgh, PA area have any audio sync problems. I've done so many resets to try and stop the audio sync and it won't stop. I've called D* and they keep saying that they will send a tech out to check the hr20 for $70.00.
I don't have this problem on my H20.:mad:
Is Dolby Digital On? I had audio synch issues when this was enabled but seemed to go away when I turned it off
How your IRD is connected to the TV can impact a/v sync. If you have audio through a home theater rcvr, that can introduce audio delay, and D* will probably not be able to assist you. Are you using HDMI directly into your TV? HDMI have been notoriously problematic and D* will instruct you to use component video and optical or RCA audio jacks.
For troubleshooting, connect directly to TV (no home theater rcvr) using composite video and rca audio (white/red cables). If that corrects/reduces the a/v sync problem, try replacing the composite video with component video cables. If that is still better than your original configuration, replace the audio connections and try the optical audio connection.
I had a real bad audio sync issue with a recording of Hero's last week. I just assumed it was bad on the live feed from NBC and not my HR20.
I will see what happens this monday and put the show on for a for mins to see if it's the recording or NBC.
Check out multiple live mpeg-4 channels. I've seen it live, not just recorded, and not restricted to HR20.... I see it on H20's as well.
HELP! My HR20-700 will not power up!
Need Help on Running Long Single Cable to R15
