I think my DG380 crap out on me??
$905.00
jibaro29
377
12
Lake Worth FL
I'm looking for guidance. I'm hoping to make the right desiccation. My DG 380 is finally dead or not. The question is can it be fixed? I took it all apart this morning including all the gears out of the motor. I pushed the west directional button and the main gear did spin some meaning half of turn. After that I performed a master reset the center gear was spinning like crazy. I thought I had fixed the problem. 10 seconds later..... back to the half turn. There are few other thing that I have notice like the motor didn't move right way after selecting a sat. Sometime the transponder signal took awhile to come on.
I looked on Sadoun's website and there is a replacement part for the IC board. I'm taking a wild guess that the IC board is the problem but before I spend more money I would like to know what you guys think.
Thanks!
How long did you run this motor, and what size/type dish was is driving? Just curious-I don't have a clue what the problem could be. My 380 has been running fine for alittle over 1yr now, and if anybody could wear a motor out, it would be me, searching for feeds lol. So far it hasn't caused me any problems.
Not quite a year turbosat. I have a 1.2 ku dish. I know that for the last couple of month it has been acting up quite a bit and today it stopped moving. It looks like I do not have enough juice to move the dish East or West. I'm getting power to the lnb but that is about it.
guapoharry; said:
Do you have a picture of the back of the assembled dish / motor?
Not at moment. I took it down yesterday. I'm using the SG2100 right now.
Too much weight involved for the motor, I wonder?
I think the 380 has a weight limit of around 30lbs, can't find the manual for it right now to see. I use a 90cm Channel master dish that is an old primestar, with the metal-mount removed. Seems like it came to around 21lbs with the metal brackets I made to hold it on the motor.
According to Sadoun the DG380 can handle up 37lbs. In all honesty it has. I have been running my dish for almost a year. So because it I'm looking into the IC board and possibly the gear motor.
Another wildlife adventure
Satellite Combo
