Need your expert's advise please.....
What is a good in-line amplifier to use?
Will an amplifier help boost signal for small 20" dish to help eliminate digitizing or signal loss after a 50' cable run and a 2x1 DiSEqC switch?
Most importantly, if I use an amplifier in a 50' run will it or can it cause signal noise resulting in snow or lines on TV images?
COMMENT:
Set up is: 2 dishes and one FTA receiver, Dish-1 is a 90cm & Invacom 0.3db single>97.0W and Dish-2 is my converted 20" Dish500>AMC-4 with std. 0.6db FTA LNBF joined by a 2x1 DiSEqC switch.
After setting up my 20" (on the roof) with a FTA LNBF pointed at AMC-4, linked to receiver with 6' RG6 cable and without DiSEqC sw. I got ALL TP's loud and clear while up on roof with receiver and small TV, but once I connected the long 50' cable leading into the house the signal dropped considerably and I can only get the strongest TP/11822H/5700.
So I was wondering if a in-line amplifier would help me.
COMMENT:
