I seem to always have lots of questions. But, I get answers here and I appreciate it.
To start, I have a 7.5 ft mesh dish, polar mouint, X2 premium HD receiver and a actuator hooked to a VBOX positioner.
Im in upstate NY so.... Latitude: 42.67° Longitude: -74.35°
I would think that 75W BRASILSAT B3 | GOES 13 | STAR ONE C3 is my true south SAT.
I did lots of reading about setting up my dish and how to determine true south, etc.
Everything I read seems to say that true south is not the same as magnetic and that you align your dish mount using true south during the installation phase.
So, I set the actuator for 0 degrees and have the dish pointed straight on with the mount. I set my declination at the proper offset (6.5 if I remember right). Here's where I have some confusion. Dishpointer says my true south elevation is 40.7 at true South and that my true South is at 193 degrees. So, I pointed the dish at 193 and set the elevation for 40.7 My problem is that I cant get any SATs in the top middle of the arc. I tried lowering and raising the dish a VERY LITTLE at a time and rescanning across the top but i get nothing.
Is it possible to have the LNB focal length off and still get some sats at good quality. When I installed the LNB, I sort of guessed on the length and adjusted on a locked in SAT to the highest level I could get. Maybe I shouldnt have dont that. I wonder if I could have been off on my aiming and tuning the LNB to that threw everything else off. Is that even possible? Seems like it could be. Another issue Im having is that the SATs closest to true south for me dont seem to have reliable active transponders that Im sure exist. So, when I brought the TV out to find a signal, I had a hard time deciding which TP to try and lock down. I appreciate any advice.
Some pics of the setup.
to this place
