Hello,
Somewhat of a newb when it comes to installing Satellite TV, but I am handy around the house and am pretty familiar with the wiring in my home. I have a Dish ViP622 Dual Receiver but am tired of only having HD in one room, so I purchased a ViP211K to solve that. I had a couple questions though..
I currently have the following setup:
Room 1 (Downstairs Living Room) TV1 and is Hi-def. (Dish 622 is located here)
Room 2 (Upstairs Master Bed) TV2 and Standard Def
Room 3 (Upstairs Loft) Mirrors Room 2 and shows the same exact same thing.
(obviously with this setup room 2 and 3 are interchangeable since they are mirrored)
So goal is to have the following setup.
Room 1 (Downstairs Living Room) stays TV1 and is Hi-def. (Dish 622 is located here)
Room 2 (Upstairs Master Bed) stays TV2 standard def.
Room 3 (Upstairs Loft) is new TV1 using new VIP211k and is hi-def.
Our house is newer and has a central wiring panel in the master closet and i have identified the wiring that goes to the rooms this post is concerned with.
My main questions are:
1. Will my current satellite support two separate receivers in the home? I can not tell exactly what kind of satellite i have but says "DISH Turbo HD" on the dish itself and "DP Plus" on the LNB housing. It has a triple LNB pointing into the dish itself. I don't understand the relationship between the number of LNBs and how many receivers I can use. Probably its one LNB per tuner.
Our house is very tall so I took a photo of the dish to get a close up. I see two wires running out of the arm going out to the LNB. Then I see a 3rd wire just cut and exposed and wrapped around the support column below the dish. I'm worried this 3rd wire is supposed to go to the 3rd LNB and its not attached.
2. Any advice on the actual install would be appreciated. There is only one wire running down into the house from the dish. That gets split with a Holland DPD2 with one coax going downstairs to the 622 and the other going to a standard splitter to mirror the two rooms upstairs. Can I accomplish what I am trying to do using more splitters in the wiring panel or do I have to actually run a new coax from the 3rd LNB on the dish into the house?
Current Install
I believe i am missing a component that must be up near the satellite itself or in our attic. Advice?
I know this was lengthly and I appreciate anyone taking the time to read and help me out.
Thanks,
Current Install
Thanks,
