International LNBF
$660.00
kelleyga
320
Does it exit?? And international feedhorn lnbF, so no extra cables needed.
I am looking at something like the DMS BSC621-2 but with international (R,L) capabilites also.
Hi Pete.
Looking/reading at the manual it looks it will do one of the other right? Either H/V or R/L? I want to get H/V and L/R , C and Ku.
The H/V or L/R polarity is controled by voltage so
H = Left hand
V = Right hand
The down side being you have to manually insert the dielectric plate one way for R and the other for L signals.
Ok, Pete, lets see if I got it right.
This will work ALWAYS for V/H and in adition I can have it ALSO do L OR R at the same time by inserting the plate.
But I can not have V/H and L/R at the same time as I could with a Corrotor II Int., Is that correct? I kind of got confused.
You will not get them all at the same time, its a C/Ku Linear LNBF, when you insert the plate it will only work in circular polarity (R or L depending what way you have put in the plate)
Do not think it will still work with linear signals at that point as I have never tried. The plates are mainly used for C-band circular signals over the Atlantic (Again never tried this)
I got an all-in-wonder card sending monitor to tv
Problem with aligment of hh120
