Internet Speed
NOODLES 36
Sep 18, 2006
Ok..so I Use The Same Connections As My Tv And Internet..sum Days My Cox Cable Internet Is Running Real Fast It D/l At Like 360 Kb A Sec..then It Goes To 7 Kb Then It Changes Back And Forth..u Guys Know What The Problem Is?
Thank U
Bogy
1,331
50
Iowa
Along with charper's question, how are you using your connection? On the days when you are getting the really slow speeds, are you downloading large files? Is your cable modem connected directly to your computer, or is it connected to a router connected to a network? Is it particular sites that slow you down?
TheForce
41,123
16,758
Jacksonville, FL, Earth
Have cable check the connections in your house. I'd bet your packet requests are getting lost due to noise and other stuff that can cause a retransmission of the data packets.
I had the similar problem not long ago and discovered that I had lost a ground on the cable modem powersupply. Well, actually, the problem was I bought a new power strip and unknown to me they had the white and black wire crossed in the strip. This caused a ground loop hum on the cable modem power supply which produced severe 60 cycle AC on the cable line. It didn't show up on the one TV I had connected to cable due to a high pass filter they had in line. Once I fixed the AC on the line, the speed returned to normal. And just for your information, the cable guy wanted to replace the modem as his solution. ( sell me a new one) The tell tale gadget I used to detect the real problem was a 99 cent hot box detector, the one with the three neon lights that will tell you what's not right with the outlet. It detected a white black wire reversed. Sure enough.
Point is, speed can be reduced by a number of problems, most of these are interferrence related that will cause the same packet to be sent over and over again until it gets through. The ping test will show that is happening but then you have to find out why.
brand new service from starband!
