I want to upgrade to the 942 and at the same time want to switch my current setup.
I want to hook up the bedroom tv to tv2 of the 942 simple enough, but since that tv is an older analog, will I be able to watch the ota locals with the 942 in use and not in use. I also want to add a dual tuner unit upstairs (322 or 625). I want to connect the tv in kitchen to tv2 of this unit. Again, I want to be able to watch the ota locals in the kitchen when the upstairs receiver is in use (very seldom) or not in use.
Presently, I have a 508 that is connected via coax to a channel 4 signal combiner instead of directly to the tv. I run a separate line for the antenna, which is also connected to the channel 4 signal combiner. This allows both of these signals to be distributed to 3 other tvs via a splitter. On any of the tv's I can watch the satellite programming or the locals.
Can this be accomplished with the dual tuner units listed above? I guess basically I need to know if the dual tuner units pass thru the antenna signal to both tuners when the receiver is in use as well as when it is not in use.
