It is on the stand alone Hopper.
I only have one Joey 1 and two Wireless Joeys and they are all linked to one out of my three HWSs and everything works fine. I would think both your Joeys should link up with no issues to your Hopper 1 or Hopper 2. Why not just try it out if possible by removing your splitter and connecting each Joey to the client ports on your Duo Node and see if you can do any linked combination you wish to do?That is how it was set up in the beginning. Things got changed when I lost the ability to see both Hoppers via Dish Anywhere. The solution we (Dish Broadband Support and I) came up with was to connect both Hoppers to the network. Unfortunately, that started all the other issues.
Tired of partial solutions, I completely rewired my system last night following the recommended Dish wiring diagram. I removed all connections from the Duo Node including old unused cables from when I had 4 Joeys. I now have each Hopper on a host port (as they were), both Joeys on a client port using a Dish supplied splitter with the second client port terminated. Disabled the wireless on Hopper 1, removed the isolator from Hopper 2 leaving it hardwired to my router, and made sure bridging was enabled on both Hoppers. Powered down all units and powered them up in my preferred networking order (Hopper 2, Hopper 1, Joey 1, and Joey 2). Hopper 2 got a good network connection and good MOCA. Hopper 1 got a good network connection through Hopper 2 and good MOCA. Both Joeys got good network and good MOCA linked to Hopper 2. Both Hoppers are now accessible through Dish Anywhere. Not sure if this will fix the Netflix buffering issue but if it doesn't, I have three other ways to watch it in my den without using Hopper 2.
I am curious about one thing though.
Could I remove the splitter from the setup and connect each Joey to a client node and still have them both link to Hopper 1 or would one try to connect to Hopper 2? Are the client ports tied to a host port or is it all software based?
Thanks to everyone who chipped in and helped me work through this.
OK, I truly understand your situation.I will try it at some point but with things now working I am a bit reluctant to switch things out and possible mess things up again. It sounds like a good project ofr a day my wife it out of town so if I do mess things up I have time to fix them before she misses out on any of her shows.
I am glad you got everything working now. I bet your issue was caused by your one Hopper connected by Wireless and the other Hopper by Ethernet. Turning off Wireless can be tricky sometimes.Yep, that is the way to get the wireless cancelled. There has been lots of confusion on how to turn off the wireless connection. Would be nice if there was an off button for wireless. Hope it helps your buffering issues too.It was but I just put in a false SSID and password. It still tried to connect but when it failed it went over to MOCA like it should. I am hoping that since the originating network connection is hardwired now it might solve some of my buffering issues.
The last tech out tried that and it didn't work for his purposes....Have you tried a HIC?
The client ports are not tied to either host port.That is how it was set up in the beginning. Things got changed when I lost the ability to see both Hoppers via Dish Anywhere. The solution we (Dish Broadband Support and I) came up with was to connect both Hoppers to the network. Unfortunately, that started all the other issues.
We really ought to raise our rates.Another satisfied customer on Satellite Guys!I'm glad it's all working well for you now.
