Jinxbox UltraHD question
iBoston
2,661
2,230
North Central
So, from what i gather.. You can have two modules in this receiver. It seems like it doesnt support DVBs2 unless you get that module?? Does te DVBs2 module back support the other satellite feeds, or do you need to split the signal two the two coaxial inputs. One for regular satellite and one for the dvbs2 signals?
Seems strange...
Correct. If you have the JB200 that will support DVBS for FTA from what I have read.
The DVBS2 module should handle dvbs and s2 if that is what you are asking.
The Jynxbox second tuner slot can be used for an ATSC or 2nd DVBS2 tuner.
The JB200 tuner is for turbo 8psk reception and used to receive Dish Network and Bell channels. While there could occasionally be dish or Bell turbo channels in the clear, the JB200 is primarily available for theft of service of Dish and Bell channels.
You need to remove the JB200 and replace it with a real FTA DVB-S2 and if you will like you can add an over the air tuner ATSC as a secondary tuner. In this way you will have a legal FTA/ OTA box. In order to use both tuner you need to load a SAFE file for a Dual model. Be carefull which file you load in yours since there are files out there with a Clone Kill feature which will kill your box if is a Clone.
Thank you.. You perfectly answered my question... Do you own one of these...
Yea, not so interested in those main stream channels.. I have Amazon Instant video for that.. I like it for the news content and the odd channels, and the unique channels. But hey, what ever floats some peoples boat..
I help a friend from this forum with one that he has strictly for FTA. We were able to found out that a DUAL file is required so the box can see 2 tuners. He realized this box runs warm when using 2 tuners so it will be nice if you can add some kind of internal/external fan. There is a Dual file which is Clone Kill safe I recalled V245. Finally, I work real hard to make the Ali channel editor to work using some of his dump files without success.:(
Reactions: Titanium
LPB Off Air?
Been out of FTA for awhile
