That is definitely not right.. I think Brittany is right and you need to do a software updateNope!, if I do it just returns to live TV. This happens on both of my Joey 4's
I turned on screen saver for the maximum two hours inactivity in all my Joey 4s and Hopper 3 Plus. Will see how goes it the next couple days for the black screen issue.The part where it goes blank screen, if you don't do anything, go to settings and drop down to device settings and screensaver and turn that to whatever the longest interval is
It replaced a Joey 3. You are right I do not have a Hopper Plus.nice, say what box did it replace ??
what are your thoughts with it after having it for a few days..
did I gather you did not do the hopper plus ??
thanks much for your time
Turn on screen saver. Read post #37.A little more info on my problem with the Joey 4. I can get into settings, but not Dish Settings. My screen saver is set to off, and it states that the software is up to date...
Are you going to the VERY TOP of the page, then right to the "gear". When you select that, you should get a list of several settings with Dish Settings already highlighted.A little more info on my problem with the Joey 4. I can get into settings, but not Dish Settings. My screen saver is set to off, and it states that the software is up to date...
larryk, scroll down to Divice Preferences then scroll down to Screen saver and then turn it on.Are you going to the VERY TOP of the page, then right to the "gear". When you select that, you should get a list of several settings with Dish Settings already highlighted.
HipKat and brittanygarden, omg, my black screen issue is fixed. Thanks HipKat for the tip. Turning on screen saver did the trick. This morning when I fired up my Hopper 3 Plus and all my Joey 4s, there was no black screen issue. Also, when backing out of watching a Hopper 3 Plus app the black screen issue was gone. brittanygarden, please inform your back shop/engineer folks that couldn't figure out the black screen issue for some folks that turning on screen saver clears up the problem. I hope I haven't spoke too soon. I am a big pissimist. If after a week the black screen issue is gone, I will be convinced. Thanks again HipKat.I turned on screen saver for the maximum two hours inactivity in all my Joey 4s and Hopper 3 Plus. Will see how goes it the next couple days for the black screen issue.
Yes, but when selecting the "Dish Settings" option it just returns to live TV, the other options in that menu do work.Are you going to the VERY TOP of the page, then right to the "gear". When you select that, you should get a list of several settings with Dish Settings already highlighted.
I seen that too.OK, here is one for the engineers... I left everything the same as it has always been, except I turned on the screen saver (I never use them and have always had them disabled) and now I can enter the "Dish Settings" options. It now appears to work as expected! Go figure... Thanks for the tip on the screensaver...
I have yet to see the screen saver come on.Stand by for comments from folks that LIKE a black screen, over a screensaver.
