Joey Warning 981
bigrex12
18
Plymouth, IN
My setup is two Hoppers w/sling and one Joey. I installed both Hoppers just fine. then I went to install and download software on my joey, and I stopped at 50% restarted and went to warning 981 Boot Recovery, and sat there all night.
So I called dish and got another one sent out so I could replace it. Download stopped at 50%, restarted and got the same warning. again, it sat there all night. Before I get a third one sent out, I want to hear suggestions or ideas, the biggest thing I can imagine is either corrupted joey software on one of the Hoppers, or a bad node. I will most likely try a solo node and only one of the Hoppers to download the Joey software.
Hit the power button on the hopper don't unplug it and turn on the Joey. After about 5 minutes it should download. The problem happens to us techs and I found that if you just hit the power button on the remote 5 minutes later the Joey will finish downloading. If that doesn't work try the same technique with the other hopper.
Reception issue ?
HBO HDCP
