Greetings to all. Just starting out with satellite dish set ups so please bear with me on my 101 questions. Not quite sure of proper component terminology but I'll pick it up as we go along.
I just had a Dish HD turbo installed on a mast in the backyard. The LNB section is a 1000.4 Sats are marked as 61.5 - 72.7 – 77 on the "menu" dish pointing screen. Instructions tell me to point to sat 110 or 119 to check signal strength.
Went through all the transponders and cannot get anything stronger the a 60 on the sliding bar graph (Meter)
I looked at the dish set up and noticed that the skew is at 90 degrees . The tech did not even attempt to adjust the skew. Why? Should I try to peak the signal or is there a reason it is left at 90 degrees?.
The teck just drove a mast in the ground and did not level it. He did not use coordinates to adjust the dish stating that because the mast is not on the bubble the coordinates are not accurate. That point is valid.
When I square up the mast and get it on bubble should I use the skew coordinates that I have for the Dish 500 HD turbo that I have? My Zip is 07851. AZ 243 EL 28 SK 126
I guess my main concern right now is why was the skew left on 90 degrees. The dish is oblong and I read that the skew applies to this geometry and not "round" dishes….true???
I will be purchasing a meter to use at the mast to peak the signal any tips on this will help. Also what basic homeowner meter do you recommend?
Thanks all Regards Juice
