Found a 12' offset with Ku feed at a local TV station one piece reflector they wanted to get rid of... wouldn't fit in the little half ton so it went to another worthy home. Would have been easy to modify for C band. It didn't come with a mount either. Ended up the engineer wanted to get rid of a 6' microwave dish too that did end up in the truck.. Works dandy on wifi!
-C.
Can you post a picture of your 6ft microwave dish, how far away signal can you getFound a 12' offset with Ku feed at a local TV station one piece reflector they wanted to get rid of... wouldn't fit in the little half ton so it went to another worthy home. Would have been easy to modify for C band. It didn't come with a mount either. Ended up the engineer wanted to get rid of a 6' microwave dish too that did end up in the truck.. Works dandy on wifi!
-C.
There are lots of reasons for 1.8m or larger Ku dishes:
1. Out-of-footprint reception
2. Very low elevation reception
3. Rain fade margin
4. DVB-S2 16PSK or higher for future
If you only have a 1.2m, your CNRs are 3.5 dB worse and you probably can't even see what you're missing![]()
1 - if are TRUELY 100% out of the footprint a bigger dish wont help you
2 - im not sure what you mean by this....if a satellite is below the horizon then you can not get it....doesnt matter how big your dish is
3 - if your having "fade" issues in certain weather conditions i dont believe a 6 footer would help over a 4 footer
4 - yes you might have a good point there
yes it does. It all depends on how far out of the footprint you are1 - if are TRUELY 100% out of the footprint a bigger dish wont help you
I think we need input from the OP before we go off the deep end.What is the largest offset Ku band dish anyone has ever seen available for sale? Are the 4 footers the biggest?
