LNB sl3 replacing a sl5
J
JackEmy
Thread Starter
Feb 9, 2016
Florida
I am trying to set up a temp installation I have a slimline with a sl5 LNB with a signal of 95%. I have a r22-200 when I put in the sl3 I bought on eBay I get no signal. How can I test the sl3 LNB
Jack
M
Mr Tony
299
49
Mankato, MN
If I remember right you need to redo the satellite setup in the menus
J
Jvfan57
70
6
WA
Wouldn't you have to repoint the dish as well?
Scott Greczkowski
Scott Greczkowski
Welcome HOME to SatelliteGuys!
Staff member
HERE TO HELP YOU!
Sep 7, 2003
100,373
19,234
Newington, CT
Nope, I went from a SL5 LNB to the new Reverse LNB 3 LNB DISH and all I needed to do was pop the old LNB off, the new LNB on then go inside and resetup the Satellite settings. It went through found the new LNB and all was well after that. :)
raoul5788
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
30,832
14,374
Cheshire CT
:welcome to Satelliteguys JackEmy!
Is the new one swm and the old one non swm? If so, you need a power inserter.
E
ejb1980
3,376
569
Vermont
And it works the other way, too, of course. All they did was take the 3 off and put the 5 on. I was glad to see that he checked the signals after doing so and all were great.
Z
Zashel
636
86
Wisconsin
Jack
as mentioned, you need to redo satellite setup. the SL5 pulls information from the 101 and 119, where as the SL3 only from the 101. so your reciever is expecting to be getting more information then it has and thinks its not working. and as stated, if the new lnb is swm thats a whole nother ball game.
and no, they dont need to re-point the dish for the 3/5, its already pointing where it needs to go.
Jimbo
Jimbo
64,704
4,696
NW Ohio - Buckeye Country
Well, again we have someone that came here for info, got the info and never reported back if it worked ...
People, please respond back to let those trying to help out know if you've made progress.
TheTechGuru
TheTechGuru
1,773
189
Texas
I went from SWM SL3 to SWM SL5 yesterday without needing to adjust anything. Although 119 signals are low...
vazhog
vazhog
299
102
United States
There is your sign - You need to re-run the sat setup - or restart the receiver (red button) or through the menu - If you are still showing the 119 - you have not reset the sat receiver to the correct LNB -it still thinks it has a SL5
raoul5788
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
30,832
14,374
Cheshire CT
He went from a 3 to a 5, not the other way around. You are right though. I went from a 5 to a 3 and was still getting signal strength readings on 119 until I redid the sat setup.
Reactions: vazhog
Similar threads
H
Replies
12
Views
12K
TheTechGuru
TheTechGuru
D
Replies
27
Views
5K
bayoubrut
B
cave1376
  • Locked
Replies
6
Views
1K
JerseyMatt
J
B
Replies
Views
849
texasbrit
T
