Hey guys!
I have an interesting situation that is further complicated by several things I have observed that make me wonder where the problem truly lies.
I am leaning toward a bad LNB at this point, but I still wanted some consensus on this.
It is my mother's system (D11-300) in the zip code 72044. Based on the zip, for a 3-LNB 18'x20", it calls for 205° azimuth, 45° elevation, and 68° tilt. I completely reassembled the dish based on these measurements and no dice.
What happens is that all the local channels (Little Rock KETS 2, KARK 4, KATV 7, KTHV 11, KLRT 16, KASN 38, KARZ 42, and KLRA 49) either give me a Searching for Signal (771), Access Card has Expired (763), or they will try to come in. When they try to come in, it may be merely audible chirps and colored blocks, or it may be most of a picture with only trouble where there is a lot of motion or transition, with unbroken audio. All other channels, starting with 70, QVC, work just fine.
The only visible thing that I found with her system that could potentially be a problem is that her access card appears to be browned, like it has gotten very hot. Most of this is around the contacts, but only the part of it that sticks out of slot is still completely white.
Now I have been informed that our locals are served from the 119° sat. I compared her measurements with mine (I have DirecTV also). I am not sure if it would make any difference, but I have a Slimline 5S with a SWM and my primary receiver is an HR34-700. Here are the results of the strength tests on 119° on both our systems (I phoned her for these so these were gathered at the same time):
Mother's:
1-8 N/A N/A N/A N/A N/A N/A N/A N/A
9-16 N/A N/A N/A N/A N/A N/A N/A N/A
17-24N/A N/A N/A N/A N/A 96 25 N/A
25-32 23 97 0 97 0 98 0 97
Mine:
17-24N/A N/A N/A N/A N/A 94 31 92
25-32 73 95 89 93 0 92 84 89
Thank you for any input!
Mother's:
Mine:
