I'm here at work, on lunch break, just wondering how others have programmed the timing settings on their harmony for the 622/722.
I have a 622 and a harmony 890. Sometimes there is a delay when issuing multiple commands. For example when I press the up arrow when browsing the guide it will only go up slowly or only once. Most of the time when I press up it will go up slow at first then start going fast.
Same when skipping ahead. Sometimes if I press skip fwd 3 or 4 times real fast it will skip fast, other times it will only skip 1 or 2 times slowly for 4 presses of the skip forward button.
It's like that for everything, real responsive most of the time then a lag others. Probably 60/40.
I also have an XBOX 360 and I have the timings spot on. The menus are very responsive all the time.
I am also using the Logitech RF extender. The equipment is in the same room and the signal only goes through a cabinet which has all the components in it. The extender and remote are programmed for the highest signal, can't remember exactly what that setting is called at the moment.
I will post the detailed timings when I get home.
Thanks.
Thanks.
