GEOSATpro Micro HD and SG9120B
Hi,
I order by error from Sadoun a DG380 when what I needed was a DG380B (my fault...). Unit was ordered on 9/27, shipped on 9/28 via USPS and still have not received it. On 10/1 I ordered the 42mm tube from Sadoun and on 10/12 I received a call advising that the tube is in backorder for at least 3 weeks.
i have a dg380 coming in with the big shaft. i have ordered a 1.2m glorystar dish from satelliteav. i certainly hope they will work together. the mast is in place, solid as can be. the rg6 cable is already run to the basement. the only thing i forgot to order is another lnb to twist 26 degrees and an adapter that can hold both lnbs. the plan is to have one lnb hooked to the 22k switch from brian twisted for nbc and the other lnb straight without the 22k signal to get other stuff. i think that would work? charlie
GEOSATpro Three LNBs Showing 0% Signa Level and Quality????
GEOSATpro Any light being shed yet on a good channel editor?
