AMIKO Mini HD SE - How do I modify Channel List?
fred555
Pub Member
7,980
7,031
77W
I downloaded the channel editor from here. http://www.namini.tk/index_files/Page318.htm
Then I go to Software upgrade, Backup to usb, select channel list.
I move the usb stick over to the computer, and on channel editor open the udf file
and nothing happens. I click on Favor Group 1, nothing.
What's wrong?
Laying here about half asleep, will give you a good answer in the morning, if someone else don't.
but make sure you are opening as a BIN file. Drop down the file type in the open screen and select .abs file and when asked select user database.
Ok I did backup mode all. I opened the abs file ok. Found the tranponder for the channels I want to edit.
I change the SID to 99 and click OK. I get an error that Audio PID1 is invalid. The Sid change is made to 99 but Audio PID1 is changed to 0. If a channel has two Audio PIDs, both error out and change to 0.
Hmmm. That is strange. I have not messed with it in a while I will have to try and look later at it.
....well I have used it lately, just not to mess with PIDs.
The Audio PIDs change to 0 by themselves after the error.
I am just trying to change the SIDs on LAFF, Bounce, Etc.. So I can rescan to look for feeds without the custom channel names reverting back to Ch-17, Ch-18 etc...
I just did some tests changing the Service ID, and it worked just fine changing to 99.
I did it on channels with single or multiple Audio PID's. They stayed where they were and I did not receive any errors.
The only thing I did not do was test with the MUX that LAFF is in, as it is not programmed into my box.
Email me your back up file, so I can work with the same one you are working with.
Reactions: fred555
I am looking at it closely and I see the audio PIDs are not right in the abs file for instance:
LAFF
On screen
VPID: 289
APID:290
In abs file
VPID: 289
APID:8482
Everything looks good. Also am editing LAFF etc no problems.
I don't know about the one in the link but try this one.
U DA MAN!!! It works,
What is the url for the proper channel editor? Mine was off the Amiko Americas site and it did not work.
What is the proper procedure for uploading the abs file?
I just successfully edited channels from my mini HD SE with the editor just downloaded from the link:
Make sure that all files included with the editor are placed in the same folder.
STB:
  • Save All and it creates an .abs file on the USB: BAK-20xxxxxxxxxx.abs
  • Remove USB from STB and insert in PC
PC:
  • Launch AliEditor
  • Open File >>> select Files of type: "Open Bin File(*abs)
  • Select the BAK-20xxxxxxxxxx.abs file
  • Click Open
  • Select User Data Base
  • Publisher could not be verified....BLAH BLAH BLAH... Click Run
  • Click on All Services if you wish to view entire channel list.
  • (or to view by satellite: Expand All Services / Expand Satellite Information / Select the satellite to edit from the list)
  • Right Click on the channel to edit and select what you want to do or double left click to edit the service parameters
  • The PIDs and PCR will be greyed out until either the channel type is changed between TV/Radio or the Service ID (SID) is modified to 0. I like using SID 0 so I can modify PIDs and match Audio and Video PIds to creat my own custom channels. For example: on NBC channels I have created a few custom channels using the same VPID, but a single APID, so I don't have to hit the audio button to toggle between the audio tracks (just change channels).
To save:
  • File Export Save as type: Open BIN File(*abs)
  • File Name: <yourfilename>.abs
  • Select Data Base: User Data Base and OK
  • The file will be saved
  • Eject/Remove USB from PC and insert in STB
STB:
  • Select your custom file
  • Upgrade mode Channel list
  • Click Start
  • Will reboot after loading custom channel list.
  • Finished!!!
You can make the channel list you factory default either during the editor saving process or after it is loaded into the STB.
Good Luck!
Reactions: fred555 and KE4EST
Well part way through typing it says new posts view them.
Brian got it so I stopped typing . :)
Reactions: fred555
OTHER X2 Premium Mini HD
OTHER traxis 6000 problem
