I have a DP1000 dish with 3LNB. The two cables come into the house, one going to a 211 receiver and the other a 301. I'm currently using a Phillips 3x4 switch which has a connection for OTA signals. I split that with a diplexer at each TV. While on the multiswitch the downstairs TV sometimes loses the sat.
and the upstairs is worse, not getting some channels at all. I'm running approx. 150FT from the dish. 1) Is there a compatible multiswitch with an OTA connection and 2) should it be powered or passive and lastly, am I at the fringe for needing an amplifier? Not using the switch, but only diplexers, I don't have a problem at either TV. I just want to clean up some wiring with the switch.
Thanks,
davisc
Thanks,
davisc
