Multiple sat hookup
aquavettes
8
Hi all. New to site and need some info. How and what equipment do I need to connect satillites 110,119,105. and 64.5 to two recievers. The installed dishes are (1) super dish for the 110.119,&105. (2) a dish 500 for the 105. I currently am using the switch installed by the retailer with the 105 disconnected and the 61.5 in its place. I would like to be able to get all four sat's connected to my 6000hd & 625 pvr receivers. Thanks for any information.
You want 119, 110, 105 and 61.5.
Right now, you have 119, 110, 61.5 connected to a DP34 switch, correct? You will need a DPP44 switch to connect all 4 satellites.
Correct I use the 500 for 61.5 sat. Also does the dpp44 swithch care whether I use both pro lnbf's and legacy lnbf's. The Super dish uses Pro and the dish 500 has legacy lnb's. What about coax? I have both ,the older on the 500 and the newer coax on the super dish. Thanks again
If I am reading this right; I will need a DPP44 and make sure all lnb's are Pro lnb's. Everything else I have in the system should work fine?
OK! Next question. How does the dish pro twin work? Does it do the switching from the 110 &119 & LNB in all internally?
New Ch 100 for 721's
Signal Levels going up and down, up and down......
