Need A/V Help...There...I said it!
illin
52
Man...never thought I would see the day when I (a computer dork) would need tech help...but here I am.
Been deployed for a LONG time now and am just about ready to come back home. I decided that a little present for me/family would be home theater stuff since our bif family thing is weekend movie night.
Anyway, I have the Dish 622 HD DVR and I need to get the sound from it to my new home theater which has "COAXIAL DIGITAL IN" and it looks more like a RCA jack. It of course has RCA in, but I wanted to get the 5.1 from Dish.
Is this even possible or am I talking apples/oranges here? I thought the audio out on my Dish HD DVR was toslink...but I dont know.
Any advice is appreciated!
Thanks,
Sean
durandal34
Apr 24, 2007
19
The 622 has toslink (optical) audio out. If the only input for digital audio is the coax connection on your HT receiver you may be in trouble. You can use the L/R stereo audio via rca but it won't be of the same quality as the optical would be.
illin
52
Ok, so it looks like I need a converter...dang.
I found Toslink to Coax coverters for around $20...I assume that I wound then need a Toslink cable from the Dish to the coverter, then a coax (rca) from the converter to the receiver. Sound about right?
I guess it is a hassel to just add 5.1 from the Dish...I am really only interested in the 5.1 for the DVD's which is internal to the receiver.
Will RCA in carry 5.1 or not? I am guessing no.
griz_fan
265
Meridian, Idaho
RCA in (the red/white two connector cable) only sends in analog stereo. Many AV receivers can apply processing on that stereo source, but there's no mistaking that for true 5.1 surround sound. The toslink to coax converter route is really the only option. Be sure to check MonoPrice.com, they have great selection and prices for these kind of things...
durandal34
Apr 24, 2007
19
The L/R rca cables will carry an analog signal. A dolby encoded analog signal can carry 5 channels of surround. This is not, however, the same as dolby digital (or dts, etc.) which requires one of the digital connections (optical/coax). I'm not sure if you can use a regular rca cable for the digital coax connection. I think not but who knows. The connector is the same.
durandal34
Apr 24, 2007
19
An analog signal can give true 5.1 surround. That's what Dolby Pro Logic is. See link: Dolby Pro Logic - Wikipedia, the free encyclopedia
Granted, the vast majority of improvements have been made in the digital arena but there is no mistaking that Dolby Pro Logic is true surround.
Ilya
XXI Century Explorer
Staff member
HERE TO HELP YOU!
33,634
22,176
NE OH
Correct.
Since you do have an input labeled "COAXIAL DIGITAL IN", that's what you should use. And yes, it will pass 5.1 Dolby Digital signal. Forget about analog connections! The signal quality will not be that good.
charper1
Bourbon Tester
18,442
6
I'm Nationwide
Just FYI for some of you - Digital Audio Inputs can be of the RCA connector variety. RCA is simply the name of a connector type AND does not always or specifically mean the Red&White/Left&Right 2chnl audio. Just like a COAX (coaxial) does not always mean the RG59/6 video cable. My 37' component video (YPbPr) cables are of the RCA connector type. And YES, you should use a better grade rated S/PDIF cable for coaxial digital audio IN and LFE Sub, not the cheap crap supplied for the 2chnl L/R audio. Something like THIS
READ UP!
RCA connector - Wikipedia, the free encyclopedia
illin
52
Thanks guys...I think I have it now. The site listed has cables ata great price...so I can get everything for less than a single cable locally!
griz_fan
265
Meridian, Idaho
D'oh! I keep forgetting about the PL2 stuff, that's one disadvantage of having an older AV receiver. I forgot the PL2 processing can now get a LFE channel out of analog stereo source material.
jlamb30
Jun 19, 2007
17
In addition to the LFE channel, PLII also gives 2 full range surround channels, whereas PL gives a limited range matrixed channel to the surrounds.
PL is 4.0 - left, center, right, matrixed surround, PLII is true 5.1.
illin
52
Guys...here is what I wound up with. The folks at this place are GREAT and got back to me asap via email. I will certainly be back to them in the future.
[FONT=Verdana, Arial, Helvetica, sans-serif]2412[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif] HDMI Cable male to male 28AWG - 6ft w/Ferrite Cores (Gold Plated)[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]2[/FONT]​
[FONT=Verdana, Arial, Helvetica, sans-serif]$4.37[/FONT]​
[FONT=Verdana, Arial, Helvetica, sans-serif]$8.74[/FONT]​
ShowLetter
ShowLetter
[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]3396[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif] PREMIUM 1.5FT Optical Toslink 8.0mm Cable w/ Metal Fancy Connector[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]1[/FONT]​
[FONT=Verdana, Arial, Helvetica, sans-serif]$3.36[/FONT]​
ShowLetter
ShowLetter
[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]2743[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]Digital Coaxial Audio RCA Cable M/M RG59U 75ohm S/PDIF Subwoofer - 3ft[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]$2.70[/FONT]​
ShowLetter
ShowLetter
[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]4044[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif] 18AWG CL2 Rated 2-Conductor Loud Speaker Cable - 50ft (For In-Wall Installation)[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]$4.50[/FONT]​
ShowLetter
ShowLetter
[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]2948[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]Optical Toslink to Coaxial (RCA) Digital Audio Converter[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]$11.20[/FONT]​
ShowLetter
ShowLetter
[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]1324[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]6 Outlet Surge Strip, Metal[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]$8.18[/FONT]​
I think that should get me hooked up. I assumed that their stuff was higher quality than the cheapy cables that came with DVD players etc over the years. The HDMI cable I have now was a freebie with a $70 DVD player, so I figured I would replace everything with a known quality.
Did I do ok?
jlamb30
Jun 19, 2007
17
Looks like you should have what you need.
I would have gotten a minimum 16 gauge speaker wire, depending on the run length.
Onkyo 605
Ps3 as dvd player?
