need help figuering out what satellites these transponders are on
from the 1st one (where it says 97) thats 89W (G28)
the 11954/V/19547 is eerily close to ABC News Now (11953 V 19532)
Do you have C-Band? G16 shows C-Band stuff
Is this the same satellite or did you move it around?
Quick observations:
The listings from the first four (G25, AMC6, AMC9, & G3C) look to be scanning the same satellite, but with a different name, except that the G25 listing has the frequency 150 higher than the others.
The G16 and G26 listings also look to be from the same satellite, but scanned with the setting as C and Ku respectively.
EDIT: And the G16 and G26 freq/sr also look similar to the first four listings.
You have to set the motor.
Is 97west your True South Sat?
How to install an HH-Mount Motor? Applies to DG240-SM3D22-STABHH100-HH120-Motech-SG2100
Enter your loaction and select Your motor from the bottom of the Sat list.
In the Sat Setup Menu, make sure to have a Live / Active TP selected.
i finally got 97w today i think my receiver and motor were having communication problems yesterday will tweak the dish more tomorrow or Tuesday
question are most of the channels on g18 scrambled
If you are getting mostly scrambled channels, you are probably next door on 121w (Echo 9), a Dish bird. What are some of the service names of the scrambled channels?
captiveworks cw600
Live Olympics CBC / NBC?
