I'm having similar difficulties setting up a dish 1000.2 antenna and my current vip211z receiver,
but it's not a cable issue. I'm glad your problem is finally resolved.
The receiver is currently authorized + working OK with a VQ 2510 tailgater,
but when using installation/point dish from the menu screen
there are no signal bars whatsoever when trying to fine tune the 1000.2 antenna.
I also tried unplugging the receiver 1st and the going to install menu.
I know azimuth is dead on using a compass + the tailgater's compass angle,
skew shouldn't matter even though it's dead on, because I covered the 2 outer
LNB's with foil so it's pointing to sat 119 only.
It could be elevation but the antenna mast is square
and elevation is within 1* and I should get some kind of signal.
Dishpointer.com settings are being used.
Could antenna LNB's being offset lower than center mean a different elevation is required ?
I bought a signal strength meter, but it only reads voltage from the receiver, as far as I can tell,
no differences in signal strength. No frequency response from the vip211z receiver signal strength application.
Might be a software update issue since the receiver is looking for tailgater switches instead of 1000.2 switches ? ... no idea.
I wish there was a Dish installer for my area.
I've lost count of how many times I've been up + down the ladder and support here seems about my only chance
of getting a 1000.2 antenna signal ATM.
