need help with 61.5
iceviper
Aug 9, 2005
16
i have a dish 500 with duel twin only one cable coming from and it picks up 119 and 110 , im trying to set up a dish 300 with a twin lbn , i connected them together with a SW21 , when i do a check switch it shows the switch as SW21 3-SAT , is this correct , and i only get a x it shows 110 and 119 and x for 61.5 is it the switch the problem are is it the dish not pointing correct
thanks single rec. dish 811 1 tv
If you're worried about aiming, the easiest way to go is to aim the dishes individually BEFORE hooking them together with the SW-21.
Also, when using a SW-21, make sure your LNBs are ALL Legacy types - NO DishPro logos.
Hard to sit still - 942 On The Way - Little Help Please
When is a 18" dish better than a 24"?
