need Help with CW-600S and KU-band LNBF in San Diego, CA
plee33
14
I am new to FTA and would like help in setting up the following:
Captiveworks CW-600S Premium, Fortec Star 80CM dish and linear Ku-band LBNF.
I do not have a motor yet. I have tried every angle possible and scanned the horizon but could not get any quality reading. I am getting 60 to 80% strength readings on most linear satellites. Could this be a bad or wrong LBNF that I got on Ebay (http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=ADME:B:EOIBSAA:US:11&Item=9730285040). The LBNF says it will work with Pansat and Coolsat but did not mention Captiveworks. The LBNF box says it's a Megasat MS1075 with the following spec:
RF:11.70/12.20GHz
IF:950/1450MHz
LO:10.750GHz
Gain:55dB
Noise Figure:0.4dB
Welcome to the SatelliteGuys.US FTA forum!
Here are all the angles from your area to the satellites.
After you pick the satellite you are aiming for make sure to have a LIVE transponder setup on your receiver and watch for signal QUALITY only as you very slowly move the dish, stopping every few mm's.
Make sure the L.O. is set to 10750 in the antenna setup screen!
Code:
San Diego, CA 92155
          Latitude 32° 40.566'N Longitude 117° 9.618'W
                       Sat Name Sat Lng Az(t) Az(m)    El  Skew
                       Amos 1/2    4.0W 257.0 243.6 -27.1 -55.1
                Atlantic Bird 3    5.0W 257.6 244.2 -26.3 -55.3
                Nilesat 101/102    7.0W 258.8 245.4 -24.8 -55.7
     Telecom 2D/Atlantic Bird 2    8.0W 259.4 246.0 -24.0 -55.8
                     Express A3   11.0W 261.1 247.7 -21.6 -56.3
                     Telstar 12   15.0W 263.4 249.9 -18.5 -56.7
                   Intelsat 901   18.0W 265.0 251.6 -16.1 -57.0
                          NSS 7   22.0W 267.2 253.8 -12.8 -57.2
                   Intelsat 905   24.5W 268.6 255.1 -10.8 -57.3
                   Intelsat 907   27.5W  90.2  76.8  -8.3 -57.3
                  Hispasat 1C/D   30.0W  91.5  78.1  -6.3 -57.3
                   Intelsat 801   31.5W  92.3  78.9  -5.0 -57.2
                   Intelsat 903   34.5W  94.0  80.6  -2.5 -57.1
                    AMC 12/T 11   37.5W  95.6  82.2  -0.0 -56.9
                        NSS 806   40.5W  97.3  83.9   2.5 -56.6
                      Pas 3R/6B   43.0W  98.7  85.3   4.6 -56.3
                         Pas 1R   45.0W  99.9  86.4   6.3 -56.0
                   Intelsat 705   50.0W 102.8  89.4  10.5 -55.2
                   Intelsat 707   53.0W 104.7  91.2  13.0 -54.5
                   Intelsat 805   55.5W 106.2  92.8  15.2 -53.9
                          Pas 9   58.0W 107.9  94.4  17.3 -53.2
                       Amazonas   61.0W 109.9  96.5  19.8 -52.3
                     EchoStar 3   61.5W 110.2  96.8  20.2 -52.2
                      Rainbow 1   61.5W 110.2  96.8  20.2 -52.2
               Estrela do Sul 1   63.0W 111.3  97.9  21.4 -51.6
                   Brasilsat B2   65.0W 112.8  99.3  23.1 -50.9
                   Brasilsat B1   70.0W 116.6 103.2  27.2 -48.8
                       Nahuel 1   71.8W 118.1 104.6  28.6 -48.0
                      DirecTV 1   72.5W 118.6 105.2  29.2 -47.6
                          AMC 6   72.0W 118.2 104.8  28.8 -47.9
                          SBS 6   74.0W 119.9 106.5  30.4 -46.8
                     Echostar 4   77.0W 122.6 109.2  32.7 -45.2
                          AMC 5   79.0W 124.5 111.1  34.3 -43.9
                      Nimiq 2/3   82.0W 127.5 114.1  36.5 -41.9
                          AMC-9   83.0W 128.5 115.1  37.2 -41.2
                   Brasilsat B3   84.0W 129.6 116.1  38.0 -40.5
                          AMC 2   85.0W 130.7 117.2  38.7 -39.7
                          AMC 3   87.0W 132.9 119.5  40.1 -38.1
                           IA-8   89.0W 135.2 121.8  41.4 -36.3
                      Galaxy 11   91.0W 137.7 124.3  42.7 -34.5
                     Nimiq 1/4i   91.0W 137.7 124.3  42.7 -34.5
                   Brasilsat B4   92.0W 139.0 125.6  43.3 -33.5
                      Telstar 6   93.0W 140.3 126.9  43.9 -32.5
                      Galaxy 3C   95.0W 143.0 129.6  45.1 -30.5
                      Telstar 5   97.0W 145.8 132.4  46.2 -28.3
                      Galaxy 4R   99.0W 148.7 135.3  47.2 -25.9
                     Spaceway 2   99.2W 149.0 135.6  47.3 -25.7
                DirecTV 1R/4S/8  101.0W 151.8 138.4  48.2 -23.5
                          AMC 4  101.0W 151.8 138.4  48.2 -23.5
                     Spaceway 1  103.0W 155.0 141.5  49.0 -20.9
                          AMC 1  103.0W 155.0 141.5  49.0 -20.9
                         AMC 15  105.0W 158.2 144.8  49.8 -18.2
                      Anik F1/R  107.3W 162.2 148.7  50.5 -14.9
                      DirecTV 5  109.5W 166.0 152.6  51.1 -11.7
                EchoStar 6/8/10  110.0W 166.9 153.5  51.2 -11.0
                        Anik F2  111.1W 168.9 155.5  51.4  -9.3
                  Solidaridad 2  113.0W 172.3 158.9  51.7  -6.5
                       SatMex 5  116.8W 179.3 165.9  52.0  -0.6
                     DirecTV 7s  119.0W 183.4 170.0  51.9   2.9
                     EchoStar 7  119.0W 183.4 170.0  51.9   2.9
          EchoStar 9/Telstar 13  121.0W 187.1 173.7  51.8   6.0
                     Galaxy 10R  123.0W 190.7 177.3  51.5   9.0
                      Galaxy 14  125.0W 194.3 180.9  51.0  12.0
                  Galaxy 13/H 1  127.0W 197.8 184.4  50.5  14.9
 Intelsat Americas 7/Echostar 5  129.0W 201.2 187.8  49.9  17.7
                         AMC 11  131.0W 204.5 191.1  49.1  20.5
                   Galaxy 1R/15  133.0W 207.7 194.3  48.3  23.1
                         AMC 10  135.0W 210.8 197.4  47.4  25.5
                          AMC 7  137.0W 213.8 200.3  46.4  27.9
                          AMC 8  139.0W 216.6 203.2  45.3  30.1
                   EchoStar 1/2  148.0W 227.9 214.5  39.6  38.6
        Satellite Finder is (c) Copyright 2004, P. Lutus
From everything you posted, all looks fine. The most notable problem for beginners (and some old timers) is LOS (line of site). What I mean is, you have to be pointed at the satellite, not close to it, but at it. Especially with ku-band. Use the angles provided by PSB, in the post above, and you should get closer. Don't give up, you'll find it. It has taken some a month or more to find it, but it's there. And once you get it, "click", you got it. Hang in there friend.
Al
I forgot to mention when I first got my dish it came with a DSS circular dual LNBF. Not knowing much about LNBF at the time. I was trying to get Telstar5 and Galaxy 10R. Of cource, I could not get any of those channels but I was able to get good quality readings on almost all the circular satellite. Are circular satellite really that much easier to receive? I was even able to see some linear ones with the circular LNBF but the quality kept bouncing from 0% to 30%. Now with the Linear LNBF I could not get anything. I just thought there might be some incompatible LNBF with certain brands of FTA receivers.
Anik F1R
What Satellite is this?
