Need receiver recommendations on 24/7 97 W C band The Walk
ken2400
1,311
149
Central NY State
Looking for receiver recommendations for receiver that is on 24/7 to receive
The Walk on 97W C band.
Will be using SD video and audio out from RCA jacks.
Most STBs AV will drift if left tuned to a single transponder, causing a "lip sync" issue. This is because they only synchronize when the service is initially tuned. If you don't have a budget to purchase a commercial unit that continuously syncs the AV, an alternative is to program a consumer STB to go into standby for one minute every 12 to 24 hours. The standby/operate cycle will force the STB to reacquire the satellite signal and reestablish AV sync. I have successfully used a consumer STB with the channel timer set to go from the tuned channel to standby every 24 hours, 59 minutes.
An inexpensive alternative might be the GEOSATpro rack units.
Lantern Update from Syed Karim, Outernet CEO
97W Gal19 Ku/3971/V/22000 <- What does it mean?
