New to the 722k, and need help...
GeneWildershair
521
Bay Area
Just wanted to know if it was possible to play all the episodes back to back within a specific group folder, without having to start them manually one right after another? Thank you.
That is called a "Playlist" function, and it would be great is Dish had it. Dish did, in fact, plan to add such a feature and in past software updates even provided the button (not yet functional) to select DVR recordings to play as a playlist. Then, one day, the button disappeared and I haven't seen nor heard anything about the Playlist function for over a year. I hope they provide some day.
how would it decide what order to play them in? Seems like an obvious answer but, you could have recorded date, episode number, first time shown date, or some way to pick the order yourself.
i ask because I am going to enter a feature request and want to make sure I ask for the correct thing.
use extreme caution when doing this!!!!!! there have been reports of the loss of ALL recordings.
I put an explanitory post about that some time ago, but here is the problem:
If you go to the DVR list, then press EDIT first, then select the desired folder, your Delete All command will mark and delete all of your DVR recordings on the drive, every last one.
However, when going to the DVR list, if you select or go into the desired folder FIRST, then select "Edit," then only the recordings in that folder will be marked and the "Delete All" command will only delete the recordings in that folder. It is the sequence of commands that is key.
I hope that was clear, and although this is precisely an operator error (meaning we are not using the feature correctly--kind of like Steve Jobs telling us we aren't holding the phone the right way) it is truly a design that is NOT intuitive. It is far too easy to forget and press "Edit" first, then select the folder, and be "fooled" because the screen will only display the first 6 of your 20 recordings in that folder, you think you are OK, but, in fact, what you can't see is that ALL of your DVR recordings have been marked.
One solution is to verify BEFORE deleting. Scroll down to be certain that only the recordings in the desired folder are marked. Remember, the key is to select the folder FIRST, then press the EDIT button.
Perhaps Dish can tweak this feature to make it a bit more intuitive. It is frighteningly too easy to delete all recordings on the drive when you think you are only deleting recordings in a folder just because you select EDIT first instead of selecting the folder first.
