October 4th Uplink Report
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
104,403
31,559
Newington, CT
Looks like a Showtime Free Preview coming up. Also looks like there may be an update later. :)
The SatelliteGuys.US Uplink Activity Report - 10/04/2006 - 23 changes
Uplink Comparison Range: 10/04/2006 12:40P - 10/04/2006 01:22P
136 - FXALT added to 119.0W TP 18 (Not Available)
281 - CSTV moved from 110.0W TP 5 to 119.0W TP 4 (A)
282 - IFC moved from 119.0W TP 6 to 119.0W TP 2 (A)
283 - DHOME moved from 110.0W TP 19 to 119.0W TP 6 (A)
288 - TENIS moved from 110.0W TP 5 to 119.0W TP 6 (A)
289 - SHO-W added to 119.0W TP 8 (Not Available)
290 - FLIX added to 119.0W TP 19 (Not Available)
291 - TMC-E added to 119.0W TP 10 (Not Available)
292 - TMCXE added to 119.0W TP 10 (Not Available)
293 - SHOCS added to 110.0W TP 21 (Not Available)
294 - SHOEX added to 119.0W TP 10 (Not Available)
295 - SBYND added to 110.0W TP 11 (Not Available)
296 - SUND added to 119.0W TP 12 (Not Available)
297 - SHOTO added to 119.0W TP 19 (Not Available)
785 - CARIB removed from 118.0W TP 3
785 - CARIB removed from 121.0W TP 13
5740 - IAD11 added to 110.0W TP 8 (Not Available)
5741 - IAD12 added to 110.0W TP 8 (Not Available)
5742 - IAD13 added to 110.0W TP 8 (Not Available)
14066 - WNET3 added to 119.0W TP 1 (Not Available)
14068 - WNET1 added to 119.0W TP 1 (Not Available)
14069 - WNET2 added to 119.0W TP 1 (Not Available)
19064 - FFTV added to 119.0W TP 4 (Available)
Channels in the system: 3070
(A) = Available
(NA) = Not Available
Last year there was one game that FOX aired two at the same time. FX carried the alternate game that wasn't on your local fox. So you will have one on FOX, one on FX. Either the FX or FX Alt will be blacked out based on what is on the local.
The only problem with this option is that it is NOT FX-HD Alt.
Rumored to be a possibility of an additional game on FX this weekend.
Be advised with this update the NHL Center Ice Channels were turned on and now appear in the EPG. Strangely absent is the NHL HD channel and any indication that tonights VS HD game will be carried.
Scott, strange your update does not show the new names for the Free Preview Showroom channels. I thought it previously had this capability.
281 CSTV MOVED FROM Tp 5 on EchoStar 8 at 110w
TO Tp 4 on EchoStar 7 at 119w Renamed ESPNU
282 IFC MOVED FROM Tp 6 on EchoStar 7 at 119w
TO Tp 2 on EchoStar 7 at 119w Renamed Bravo
283 DHOME MOVED FROM Tp 19 on EchoStar 8 at 110w
TO Tp 6 on EchoStar 7 at 119w Renamed TDIS
288 TENIS MOVED FROM Tp 5 on EchoStar 8 at 110w
TO Tp 6 on EchoStar 7 at 119w Renamed SHO-E(not available)
289 SHO-W ADDED TO Tp 8 on EchoStar 7 at 119w(not available)
284 DIY became FLVNG
285 FSESP became HTV
287 NFLHD became RAVE
It had problems last month too. The only way we are going to get this to run 100% is to clone you john (and store you in a computer) :)
It does with the information changes... my snapshot from around 1pm central still has the old names but with the TP moves. I thought it was weird but it must be in the middle of the changes as I don't even have the RAVE one.
Let me re-run it again...
The SatelliteGuys.US Uplink Activity Report - 10/04/2006 - 34 changes
Uplink Comparison Range: 10/04/2006 12:57P - 10/04/2006 02:06P
136 - FXALT - 119.0W TP 18 changed to Available
281 - CSTV renamed to ESPNU (A)
282 - IFC renamed to BRAVO (A)
283 - DHOME renamed to TDIS (A)
284 - DIY renamed to FLVNG (A)
285 - FSESP renamed to HTV (A)
287 - NFLHD renamed to RAVE (A)
288 - TENIS 119.0W TP 6 changed to SHO-E 119.0W TP 6
540 - NHL - 110.0W TP 16 changed to Available
541 - NHL - 110.0W TP 16 changed to Available
542 - NHL - 110.0W TP 24 changed to Available
543 - NHL - 110.0W TP 24 changed to Available
544 - NHL - 110.0W TP 24 changed to Available
545 - NHL - 110.0W TP 24 changed to Available
546 - NHL - 119.0W TP 18 changed to Available
547 - NHL - 119.0W TP 12 changed to Available
548 - NHL - 110.0W TP 24 changed to Available
549 - NHL - 119.0W TP 10 changed to Available
550 - NHL - 119.0W TP 18 changed to Available
551 - NHL - 110.0W TP 24 changed to Available
552 - NHL - 119.0W TP 12 changed to Available
553 - NHL - 110.0W TP 24 changed to Available
554 - NHL - 110.0W TP 24 changed to Available
555 - NHL - 119.0W TP 21 changed to Available
556 - NHL - 119.0W TP 21 changed to Available
557 - NHL - 119.0W TP 10 changed to Available
558 - NHL - 110.0W TP 24 changed to Available
6226 - WDBJ - 110.0W TP 25 changed to Available
6227 - WSLS - 110.0W TP 25 changed to Available
6235 - WFMY - 110.0W TP 31 changed to Available
6236 - WXII - 110.0W TP 31 changed to Available
6410 - XETV - 110.0W TP 29 changed to Available
8534 - KUWB renamed to KUCW (A)
9295 - WFXU renamed to WTLFD (A)
(A) = Available
Second set of changes for today ;)
Now if only I talk JohnH out of his TID conversion list!
Yeah just got my 211 for the BR activated in and I noticed that FXALT when ahead and put it in my Favs..
Thou shalt not do uplink activity between 55 and 00 and between 25 and 30. Use might not get a complete version of the tables. :)
Other computer has info you request. Memory span is sometimes short. :)
I did mine an hour later and it was still halfway changed ;) (Scott's time is eastern...and mine is central). Maybe I should add that designation to the times on the top. Hmmm...
no!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
what the f is this for!!
dish sucks!!!!
this is already an mpeg2 channel and I already get this and hdnet and hdnmovies remains down converted :(
Who would even have a Vip receiver and an HD tv hooked up through component or HDMI and not have HD service? If you are eligible for the previews I bet you already get these stations. There is nothing that my cable company didn't have in their basic package. At least last month they had FSN-Espanol, now they have crap!
Worldsport would have been a better choice for upgrading to VIP series, but apparently there are some problems with people not upgrading to the additional slot for HD.
Pittsburgh Hd Locals
[RANT] Why is the ViP622 such an upidstay nituay?
