Odd 622 Remore Control question
Videomax
55
Hi,
I'm having Dish network with a 622 receiver installed tomorrow. The receiver is to be connected to an HDTV in the living room. The second tuner within the receiver in going to operate an SD TV a couple of rooms away.
How the does remote control work on that SDTV if the 622 receiver is a few rooms away?
Thanks,
Dave
RobertsD
443
Layton, UT
It comes with two remotes, the first is for TV1, and is an IR remote, the second is for TV2 is and is a UHF remote, which works through walls, floors, etc.
csalmon
Jan 2, 2005
14
I have a question about these 622 remotes. I have my system set up in single mode and am only using one of the remotes. Is there a way to set the UHF remote as the main (TV1) remote? I would like to use that one instead of the IR but it seems to not respond while in single mode. I tried to find this in the manual but must have missed it...
csalmon
Jan 2, 2005
14
Ahh, I got it after reading a little more in the manual. I had to confirm the remote 2 address in the system info screen. The 622 defaults to address 1 but the remote was on address 6. Now it works like a charm.
navychop
Member of the Month - July 2014!
60,016
27,290
Northern VA
So would an address 1 for UHF on a ViP622 conflict with address 1 on a 721? My neighbor and I both have 721s, I had to reassign mine to 12 when he got his. Now I wonder if I should start off with a different address.
navychop
60,016
27,290
Northern VA
Thanks. I'll remember to tell the installer right off to use a different address.
