Hello, as you can see by the system in my sig I have two HR20-700's. For the past 2 or 3 weeks, when I get home from work, one or the other (but never both at the same time) will lose one of the tuners completely (771). That is to say, when I check signal strength I get all 0's on one of the tuners. A normal system reset clears this right up thus far & each HR20-700 is good to go for the rest of the night.
I know this could be a LNB that is starting to fail, or the Zinwell 6X8 or (outside chance) that both of my HR20's are slightly on the fritz. I am leaning towards the Zinwell.
About 2 months ago, my daughter complained that here D10 was not working (771). I discovered that apparently there was no signal coming out Zinwell on the port going to her room. So since my older step son had recently moved into his own apartment, I just switched her room to that port. So of the 8 ports, only 7 were actually plugged in. Well my brother-in -law came to live with us 3 weeks ago & I had to pug that 8th port back in. All is good for about a week until we get to the first paragraph of my post.
My question is, should I try to call D* now & try to steer them towards coming out & either confirming the Zinwell as failing/or whatever my problem is, or just wait until it fails completely? Remember a reset, thus far, has fixed my problem. TIA
