My review of the SSO as biased by my previous experience with a Pansat 9200.
(thought it would have been done a day after the previous post, but hey, it's finally done)
SSO = SatHawk/Solomend/Openbox
Programming Sats. Well here I have to say I had an advantage as the GBox had already been programmed with all sat positions from 137W to 53 W. This saved me some time, but think it wasn't much.
Operation of the GBox and Disqc switch by the Openbox has been flawless.
Select sat with a check mark, to program the sat, in the Sat List, then back out and re-enter Abtenna Setup to program a sat.
Blind scans are FAST! I would say it's 50% faster overall, than the 9200. Does it miss anything? I would have to answer that with "sometimes" It has missed a few. On ocassion, it has missed an active programmed channel when rescanning a sat. Scanning a second time usually gets it. So most of my blind scans are repeated, (wildfeed hunting) Some Weak signals have had to be TP scanned (in the TP List) to get.
The DVR function uses a common USB drive where the Pansat requires an eSATA drive. Use of an externally powered USB HDD seems to be required. Many USB HDD's draw more power than the SSO can provide.
The clock works, meaning that timed recordings are possible. (The clock in the 9200 is "crap")
The SSO must be left ON for the clock to keep time. (Software clock instead of a hardware clock) DVR operation, on a 8Gb usb stick and a spare HDD with a USB/SATA adapter cable, has been flawless.
A timed recording will shut the receiver off when it's done! Meaning, you can only use one timer recording.
The clock format is Military and cannot be changed to 12 hour format.
The date format is also military, I.E: Day/Month/Year
Runs a whole lot cooler than the 9200, and doesn't need a fan. Might even be cooler than the Pansat 3500SD. Does audio formats that the 9200 doesn't.
Negatives:
The three things, I think, that the 9200 has over the Openbox S9:
1) a more user freindly menu system.
I.E: It takes less keystrokes to program a sat, edit TP's or just normal operation with the 9200.
2) the Openbox does not identify any info for the channel except for the PID's. No way to tell if it's S2, 8PSK or QPSK. No Pilot on/off in TP scan, or indication if pilot is used. This is not a big problem, unless you need that information for another receiver.
3) No way for manual PID entry. You must do it with the channel editor run on your computer. Easy to do, but just not as user friendly.
Other quirks in the Openbox, and would apply to all brands, (SSO)
The composite video out has a noticable green tint. (with 480i V Format selected)
I don't know why. but some channels seem really "green" and others are not as noticable.
Another is the Channel/Sat selection function. Hit OK to see the channel list, you can scroll up and down, then select another channel on the list with the OK button, and the receiver goes to that channel.
BUT, if you hit left/right, the receiver immediately goes to the next sat. I wish it would wait until I make a channel selection on another sat.
This flaw makes the Recall (last Channel) function almost useless. There is a way to use Recall, with two channels on different satellites, but it requires many, many more, keystrokes to set up.
When recording using the (instant)Record Button, to stop the recording the keystrokes required are STOP, LEFT, OK. Why not make it STOP X 2 ? Hitting the stop button twice would be so much more convienient.
Hitting the Record button twice brings up a little window with 02:00 in it. The format is: Hours:Minutes (I don't know why I couldn't figure this out myself, I was stuck on minutes
s)
I miss, after a blind scan with the 9200, how it went to a preview mode where you could see the channels you just scanned in. Exiting the preview mode, with just one keystroke, put you back in the scan menu.
With the SSO you must completely exit the programming mode to view the channels. Quite a few OK and Exit keystrokes are required. (but hey, I sometimes scream at my computer to "KEEP UP WITH ME")
Things that need to be fixed in the SSO's, in order of priority.
1) The receiver shoud NOT turn off at the end of a Timer recording. (!)
This makes all the timer functions listed unusable, except for the fist one.
2) The Left Right buttons should not cause an immediate change of channel/sat
when in the channel list. Wait until I make a channel selection.
Same should also apply when selecting a satellite from the satellite
list, just show that satellites channel list, but don't change sat/channel
untill I select a channel. Fixing one of these functions, means they
could delete the other function.
3) The green tint of the CVBS output has to be fixed.
It was good until a firmware update.
4) A rescan of a satellite should not rename channels I have manually named.
These first four should be fixed, in my book, to take a very good
product to the level of an exceptional product.
The rest are minor and only address user friendlyness, such as:
To stop a recording in the instant record mode should be just STOP x 2.
PID entry and TP information display.
Can't think of anything else.
Overall, I like the Openbox very much, I like my 9200 almost as much, but that may change when I finally get around to repairing the P.S. and do the heatsink mods.
