OTA channel guide for Hopper 3
Jim5506
8,457
4,129
Slaton, Texas
Recently Lubbock Texas TV channels KCBD 11-01 (RF11) and KJTV 34-01 (RF 35) unexplainedly swapped frequencies. Guide for KCBD 11-01 and Dish channel 11-00 are the same as they should be, but KJTV 34-01 and KJTV 34-00 the guides are different. Some how channel 34-01 has the same guide data as channel 32-00, which makes it impossible to record anything off the OTA KJTV 34-01. Can somebody look into this and fix it?
The reason why they swapped frequencies is such
This proposal will serve the public interest because it will allow SagamoreHill to replace KJTV-TV's failing equipment with the working equipment currently used by KCBD. KJTV-TV's tube transmitter is currently failing, and replacement parts for tube transmitters are not available. The cost for SagamoreHill to replace the transmitter for KJTV-TV's 1000kW facility is prohibitive. Gray, for its part, was already planning to invest in a new 1000kW transmitter for KCBD (as granted in KCBD's channel substitution petition). To maximize the existing equipment in the market, Gray and Sagamore have agreed that in lieu of constructing a new Channel 36 facility, KCBD will move to KJTV-TV's Channel 35. Because KCBD will not be building a new Channel 36 facility, it will be able to bear the cost of replacing the Channel 35 transmitter. KJTV-TV will move to Channel 11, KCBD's current channel, operating with the existing Channel11 equipment, all of which is in good operating condition
When two stations share a broadcast frequency the Dish guide shows the guide data for the -01 channel on the -01 guide as well
Dish has said in the past that they cannot fix this with the existing guide technology
Looks like they fixed this problem. Now 11-00 and 11-01 are the same guide data.
Actually they have said that they could deliver more complete guides if they delivered it by the internet. They have not done this but it apparently is possible.
My newer LG set's OTA Guide comes from the Internet. It is populated as soon as you call it up. I think the older one may use the PSIP data.
The FCC Listened to You — NextGenTV DRM Is In the Hot Seat
