OTA signal issues
tsunami2311
402
452
NJ
So I have recently setup Indoor OTA due to drop to Local from Dish, and found out reason why I have such bad signal is my Monitor now none of cable for my monitor near OTA or it cable going to TV, but the TV right above my Monitor maybe not even a foot.
If i have 3 to 2 bars with monitor off said channel for most part of perfectly watchable, but as soon my monitor is ON (show image of desktop or what ever) OTA going to TV halved that 3 to 2 bars become 1 and 2 if I lucky and channels start scrambling alot, and depending on what is being shown on monitor it might out right give no signal, and I can easily restore singal to being bad if change what show on monitor or bring back 3 to 2 bars if I turn monitor off or let it to to standby mode.
I have already disconnect every cable on TV except the OTA cable leaving just that so it not those cable. the Power cable for monitor and DP to DVI cable the monitor is using no where near that OTA cable either.
Any idea on how to fix this? moving my monitor isnt exactly an option neither is moving the tv and moving the OTA to other side room even with long cable dont fix this issue.
I have one those Leaf MoHu antennas 11x3 ones, I had same issue with one gateway mohu antennas the older one too
Do you have any splitters or combiners in between the antenna and TV? That can cause issues, especially indoors.
I would get that antenna into the attic or outside if at all possible.
And we need your Rabbitears reception report to really be able to provide answers specific to your location-
no spilter is just for my tv
I get I just need to short out the monitor from kill the signal to the tv cause the monitor being on and show image basically castrates signal
I just moved wires around moved power cord away data cord and what not, and some made this issue worse just have my monitor on and show image was enough to just kill signal, I went and moved monitors data cable DP to DVI cable and it came back even if was still spotty at best, now I think it DP to DVI cable I using considering moving seem maninpulate how bad the signal that cable is still no where near OTA cable or any cables going to the tv, the tv and monitor are on the same surge protector though
Umbrella base for pole to fit antenna
