OTA signal issues
$735.00
tsunami2311
405
452
NJ
So I have recently setup Indoor OTA due to drop to Local from Dish, and found out reason why I have such bad signal is my Monitor now none of cable for my monitor near OTA or it cable going to TV, but the TV right above my Monitor maybe not even a foot.
If i have 3 to 2 bars with monitor off said channel for most part of perfectly watchable, but as soon my monitor is ON (show image of desktop or what ever) OTA going to TV halved that 3 to 2 bars become 1 and 2 if I lucky and channels start scrambling alot, and depending on what is being shown on monitor it might out right give no signal, and I can easily restore singal to being bad if change what show on monitor or bring back 3 to 2 bars if I turn monitor off or let it to to standby mode.
I have already disconnect every cable on TV except the OTA cable leaving just that so it not those cable. the Power cable for monitor and DP to DVI cable the monitor is using no where near that OTA cable either.
Any idea on how to fix this? moving my monitor isnt exactly an option neither is moving the tv and moving the OTA to other side room even with long cable dont fix this issue.
I have one those Leaf MoHu antennas 11x3 ones, I had same issue with one gateway mohu antennas the older one too
Do you have any splitters or combiners in between the antenna and TV? That can cause issues, especially indoors.
I would get that antenna into the attic or outside if at all possible.
And we need your Rabbitears reception report to really be able to provide answers specific to your location-
Reactions: Foxbat
no spilter is just for my tv
I get I just need to short out the monitor from kill the signal to the tv cause the monitor being on and show image basically castrates signal
I just moved wires around moved power cord away data cord and what not, and some made this issue worse just have my monitor on and show image was enough to just kill signal, I went and moved monitors data cable DP to DVI cable and it came back even if was still spotty at best, now I think it DP to DVI cable I using considering moving seem maninpulate how bad the signal that cable is still no where near OTA cable or any cables going to the tv, the tv and monitor are on the same surge protector though
Are these items all Grounded ?
You haven't defeated them ...
Make sure the outlet is grounded as well, if it's nothten nothing else is.
Sounds like there may be some RF coming from your monitor (presumed to be a computer monitor?) being picked up by the TV's proximity to the monitor.
Move the TV or the computer at least 5 ft away.
If it is cabling to monitor it would show up while the computer is on and whether the monitor is off or on.
Maybe wrap the monitor in aluminum foil? Just as a test to see if it's radiating RFI that's overwhelming the OTA tuner. Obviously not a viable long-term fix.
Waving T-Mobile GIF by Magenta
  • Haha
Reactions: navychop and Foxbat
Far as i know they are all ground as surge protector is grounded this particular mode APC PV11V3 has wiring/fualt light that should go on if it not grounded and it not on protection light is green and on too . I not very knowledge about all that electrical grounding so i just go by what it tells me, my other surge protecter has grounded light on I could probably just plug to same outlet this one is to see if actual grounded
Monitor has 3 prog power cord the TV is 2 prog
Sadly moving the monitor (Asus VS248) is not really an option I would have move my entire room which I not about to do. Computer is under desk said monitor is on, but turn the computer off does stop signal from droping so long as monitor is on, as I test that by connecting my ps5 to that and it happened there too
I do know that Moving the DP to DVI cable under desk can and does effect the signal, depending on where that cable is I might have spotty signal or no signal out all with the monitor on. but soon as it is off signal is fine.
The DP to DVI cable is shielded and the coxial cable is a shielded RG6 cable
I will see about moving the monitor 5+ feet way just to see if proximity to tv is issue. but that wont really solve my issue cause moving desk and there for computer and monitor isnt really option
worth try I see what happen when I get hand on some aluminum foil
So, the TV is Not Grounded ...
I'm interested to see what happens when you move the TV away from the rest ...
TV is fix mounted to wall on metal brackets it can tilt and slide to side that is it it it 8 feet off ground and 55" tv it not getting moved . if it ground issues on TV how how can I fix that? I thought if surge protector is ground so are devices
It TCL 55S515 TV I have 2 of them in house both are 2 prog and most TCL tv I seen are 2 prog maybe there bigge sets are
Can you move the Antenna away from the monitor ?
Antenna is 8 feet away from tv I tried put 10 feet way didnt make difference
If I being honest after NHL Stanley Cup games I will probably stop caring and disconnect the OTA anyway cause I dont watch anything on anyway just my mom does and she attenna on here tv that really not much better it just dont have singal halve issue I have but it would be nice if I could fix,
probably the easy fix would be to get Tablo put antenna in attic like dad thinking of doing run coaxial to tablo and let feed tvs that way
Well, it's grounded up to the Surge Protector anyways ... but if not 3rd prong, it's not grounded ... I don't recall if my TV's have a ground, guess I never thought about it ...
Now ya got me curious, I got to check.
Well, thats interesting, I thought all TV's were grounded ... guess not, maybe they figure if the voltage gets that far, its not going to save the TV ... :(
Double insulated.
yes my tv is double insulated. could that be part of my problem?
I dont even get why my monitor and or the DP to DVI cable is causing this the cable is shield for this stuff yet moving that cable obviously effect the ota signal and simple act of that monitor be on cuts single in half, monitor on but in standby mode is fine, as far as i know computer gpu? is still out puting signal to monitor even when the monitor is standby mode it just dont wake up till the mouse or some input moves
aluminum foil over my monitor did stop the issue or even help in the lest
Something to try. Using an extension plug the TV into a completely different source of AC. Monitor may be feeding noise back into AC.
Reactions: FTA4PA
AVC codec being used locally OTA
