New Message on OTA station
richardrosa
8
4
Marlboro, NY
Greetings All,
For the past year or so, I have received WVIT on RF Channel 33 with no issues. This is an ATSC v3 station out of Hartford, CT.
There are also 4 other stations transmitting streams on this channel.
As of this past Saturday, the following message is display on my Sony TV when I attempt to tune WVIT:
"Cannot view channel because the TV's licence is being updated or
another problem has occurred"
This message also shows up on one other stream (WFSB). The other stations all receive with no issues.
I Have checked the signal level of Ch 33 with a spectrum display, and it appears to be OK.
My location IS is a bit of a fringe area for reception (Marlboro, NY),
but up until this issue, I've been able to receive CT. stations without too much trouble
(NYC stations are blocked by mountains).
Unfortunately, I do not have any other device available to tune ATSC v3 to determine if this is a station or TV issue.
Any ideas what is going on?
Thanx.
Richard Rosa
I'm in the Hartford area and off air WVIT is normal. Seems like a strange message.
Are you receiving the stream on RF channel 33 (ATSC v3) or the WVIT signal on Channel 31 (ATSC v1)?
Channel 31 does not have this issue. Ch 33 is needed, as my reception on Ch 31 is somewhat 'iffy'..
Thanx.
Richard Rosa
The ATSC 3 versions of WVIT and WFSB are coming in fine for me. I am about 8 miles away from the tower.
I checked on my Sony TV which has a ATSC 3.0 tuner. I also checked on my HD Homerun and both are showing as Encrypted. But the other ATSC 3.0 channels are coming in fine on it which are not Encrypted.
If I understand this correctly, WVIT & WFSB are now encrypted? Does this mean they will be charging for reception? This does not sound good.
I get so few OTA signala here as it is...
Thanx.
Richard Rosa
They have both been encrypted for about 6 months now. If you are not getting them and were before today I am guessing the weather (snow) may have something to do with it. But we will be back in the 50's on Monday so it should ome back for you. :)
They were being received up until last Saturday (12/20) when the message started appearing when the station was tuned. So I don't think it is weather related.
I spent several hours checking all the antenna connections when my Wife mentioned that she could no longer get the NBC news broadcasts :-(
The signal level does NOT look any different from what it was two weeks ago.
Unfortunately with Digital (and especially v3) it is difficult at best to determine if there are reception issues or content issues.
Thanx for the info.
Richard Rosa
The company I work for owns the antenna on Rattlesnake Mountain where those ATSC 3.0 signals come from. I will check with Joe tomorrow and see if he knows if they made any changes to their encoder.
Looking at thing it appears they chaned WFSB from 1080p to 720p over a week ago.
I would delete those channels from your system and then do a rescand and see if that helps.
I will let you know what Joe has to say. (If he knows)
Thanx for the suggestion. Unfortunately, this set does not allow for removal of individual channels,
so a COMPLETE rescan was required.
It was a nice idea, but still didn't fix the issue with the two streams...
What is frustrating is that about a year or so ago, WVIT & WFSB v1.0 channels were strong, and
easily received. Now WFSB (Ch 36) only comes in sporatically, and WVIT (ch 31) has some sort of
interference that makes it hard to watch.
It's doubly annoying as I do not watch TV.
I'm more interested in the other sections of the Radio Spectrum...
This is for my technologically challenged Wife, who does NOT do computers or streaming :(
Looking forward to what Joe has to suggest..
Thanx.
Richard Rosa
Richard,
What ATSC v3 Sony TV do you have? Is it connected to the Internet? It sounds like an older device and the station updated their encryption keys, now your device can't decode them without an update on its own.
Reactions: navychop
Thanx.
Richard Rosa
Check online for an update for your tv's system. Maybe there's a new one that'll fix it. It IS connected to the internet, correct? You are using a tv set with a 3.0 tuner, and not an outside 3.0 tuner device?
Not sure older ATSC 3 equipment can ever be updated to the still changing ATSC 3 standard.
Richard,
It's a model KD-50X80J. It is NOT connected to the Net. My router is on the opposite side of the house from the TV, and does NOT have Wi-Fi (never had any need for it).
The firmware WAS updated a few months ago (with a REALLY long Ethernet wire).
I'll drag out this cable again and see if there is another update...
If I gotta be connected to the I-Net to get OTA TV, it kind of makes the Antennas superflous :(
Richard Rosa
Both WFSB and WVIT have an interactive service which requires an iinternet connection to fully function.
I have a feeling that the encryption keys for both channels changed and your TV will need to be hooked up to the net to download the new ones. Once they are downloaded they shouldnt change again for awhile.
This video may interest you.
View: https://www.youtube.com/watch?v=2ua5r7krryM
Yup, that appears to be the issue.
I went through the grief of updating the set's software.
I had to disable my VPN (enabled in my router).
The SONY does NOT recognize the I-Net as being connected if it is through a VPN!!
Once the update was complete, WVIT & WFSB streams worked....
UNTIL I removed the temporary Ethernet connection!
If I gotta run a whole new Ethernet cable, and get a second router, I think I'm gonna suggest to my Wife that she read more books :confused:
Thanx to all who responded,,,
Richard Rosa
Glad this has worked out and you figured out the problem.
You may not have to run a cable over to the TV, depending on your router you may be able to get a Wifi extender and put it near the TV. Many extenders have an ethernet jack on them, which you can use to plug into the TV.
Hope this helps!
Hope this helps!
This is, of course, unacceptable for a broadcast TV service. The whole point is to be more reliable than the local internet connection.
- Trip
I just did a test using my Sony X90J. I tuned into both of the ATSC 3.0 signals that have DRM on with Ethernet plugged in and was able to tune into both fine, and the interactive features of both channels worked.
I then tuned to an ATSC 2.0 channel and unplugged the Ethernet cable from my TV and tried tuning into both DRM channels again. Both channels loaded and played fine without the internet connection. However the interactive features did not display or work on the channels.
I then plugged back in the ethernet into the TV and within a few seconds the interactive features appeared on the screen.
So on my TV they do play no matter if the TV is connected to the internet or not.
I have reported my findings to Lon from Lon.TV.
Reactions: Foxbat
I've had intermittent ATSC3 reception problems cured by changing a menu setting regarding internet access for interactive services. This may be accessed by Navigate to Settings → Channels & Input → Preferences (Channels) → Interactive application → Turn off the Enable Interactive application setting. Or something similar…might be "Authentication for TV services" on some TVs as the menu titles seem to vary and I didn't double check. Only one ATSC3 channel here (KNBC) has interactive services and those features are slower than dial-up so no loss.
The whole DRM, authentication, licensing, and interactive services via internet remain confusing to me so I welcome clarifications and corrections. How much (or how often) a TV needs internet access if streaming services aren't desired seems uncertain…at least to me.
The Sony TV receives two ATSC3 channels not decoded by HDHomeRun (due to DRM). And, of course Tablo is ATSC1 only. This whole situation is frustrating since ATSC3 signal levels can be better than ATSC1 in my specific location about 60 miles from transmitters.
Silicondust launches Grand Slam MDU TV
KNGC-LD launches in Lafayette with Gulf Coast SEN as the main affiliate.
