Pentagon Channel problem
cablewithaview
Stand against retrans!!!
398
DeKalb County, AL
I pick up Pentagon Channel off of G10R ku, I have been having problems with my audio the last couple of days, is anyone else having this problem?
My settings are VPID 262, APID 0268 & PPID 8185. It seems though this feed has always had some sort of problem though. thanks
No sound on Pentagon Channel on G10R ku but on IA 5 its ok
cable
Pentagon does have some issues. Either audio cuts out or its not in sync. Theres a couple options
-manually load the PIDS in as 262/268/262 One time somebody figured out if the video & PCR PID's are the same the audio delay is gone
-It is also on AMC1 (103W) 12100 V 20000 The skew is different for AMC1 (has to be like -25 off normal skew) but it comes in with no issues. There's 2 feeds there (one with normal audio and one with AC3)
Iceberg said:
cable
thanks, I'll try the PID's and go from there. I know when I talked with the Pentagon Channel a while back, they said the G10R feed was not there's and wasn't for sure who had that signal. I had asked to make sure which feed to use when I put it on the cable back last year. I am using a D9834 at work and noticed both audio feeds where different but I do receive both fine on AMC 1.
I dont know who carries it on G10 either. Only thing I can think of is maybe its there for Alaska maybe (since they cant see AMC1)
The Pentagon website shows AMC1 as their satellite
PanSat/CoolSat - Parental Controls
Help to find satellites
