Primestar elliptical
olliec420
759
187
Pensacola, FL
I just got an old primestar elliptical dish from a friend. the lnb has 2 outs on it. does that mean that it had 2 lnbs in there? any way of picking up galaxy 25 with that thing? and if so, which of the 2 out puts on the lnb am i going to be using? thanks for you help!
yes it will work for G25 (IA5)
The 2 outputs each have one polarity on it. So one output is V only and one is H only. You can either change out the LNB or get a 3x4 multiswitch and hook both lines into that. The switch will give you 4 outputs then and both polarities :)
Yep thats a great dish for G25, I have one on a motor and one stationary just for G25. Definitely get the switch so you can get the most programming.
Those Primestar LNBFs work great. I have been testing different LNBFs on my recently installed 1m dish this past week. I find the original works the best and looks cool too.
The ones with separate H and V outputs are actually quite useful when a 2 x 4 or 3 x 4 multiswitch is added. Makes them equivalent to any other dual-output LNB :)
Found A Free Muzak Dish
Samsung DSR 2800 c/i
