Problem when I switch from Bonus View channels back to regular Dish channels
$905.00
teachtom
3
3
Texas
Hello everyone, new guy here. I'm trying to solve problem I'm having with Dish bonus view channels. When I'm watching the bonus view channels then I switch back to regular dish channels, after few minutes the screen flips to black and after 30 seconds flips back to regular channels and continues to flip back and forth until I turn off TV. After I wait 30 minutes and turn back on , I can use regular channels again. So, its after I switch from bonus view channels to regular dish channels the problem starts. Been trying to fix this for a month, but no luck
Here what I've done.
i contacted Dish support and they sent me a new Joey3, but no help. Switched to a different HDMI input on TV, no help. Used different HDMI cable , no help. Used different electrical wall plug, no help.
Finally got a Dish tech to check it. He ran all systems check and was OK. Finally he brought in a small TV and plugged in the HDMI out from the Joey to the small TV. He could not get the problem to occur on his small TV, so the new Joey was working OK. So, then the problem must be myTV. He made some phone calls and came back with the answer that there must be a problem with the analog to digital switch in my TV. Has anyone ever heard of a problem like this, or is it time to be looking for a new TV? My tv LG OLED65C8PUA. TV has been trouble free til now. Thanks
First off, great TV. I'm torn between the 77C5 or the 77G5.
It sounds like the handshake between the Receiver and the TV is having a problem. Are you using the free cable that came with the Joey or a higher speed HDMI cable?? That's the f irst place I'd look
First off, The analog to digital switch, also known as the digital television transition, is the process of converting older analog television broadcasting technology to digital broadcasting. It's used through coaxial cable for the an antenna during the mandatory switch from Analog to Digital on June 12, 2009. You either had to get a converter for your analog (Tube TV) or use a converter box that has the analog or digital tuner or an HDTV which your is and has the tuner built in. Your TV is HD and using an HDMI Cable and nothing is connected by coaxial cable so this wouldn't apply.
In my theory it probably means a new TV. I had a TV go out on my switching between the Smart Screen from the HDMI inputs before because they went faulty. Sometimes electrical surges can cause this. If you have an older home or rent an older home or apartment sometimes the electrical outlets are not grounded and these days HDTV's need a ground which can cause them to malfunction and go bad quicker. Never plug it directly in an outlet. It will damage the TV.
Hope I could be of some assistance.
RJ T.
From Illinois
RJ T.
From Illinois
Thank you for the information. I do keep the TV plugged into a surge protector, but we have had pretty strong thunderstorms/lightning in the last month so that have contributed to my problem.The house was built in 2009 so everything seems to be grounded correctly. We have had a power surge also. Seems like no one fixes anything any more, so just get a new one or live with the problem. Thanks
I think the HDMI cable is good, i used one of my own from my 4K atmos system, i'll switch it with another just to check. Also I have a bid in at Greentoe for 77" G5. Thanks
I've had this problem with my older Sony TV. It happens when I just punch in a regular channel number. The only way it works right for me is to push guide and select a regular channel from the guide screen.
audio levels from channel to channel
Price Increase on Owned Equipment?
