problems splitting ota to two hd receivers
onyx3751
Versailles,Kentucky
I have two dishnetwork hd receivers(921 and 811),and recently put a uhf/vhf antenna up in my attic,and got perfect signal on all ota hd channel, signal strenght ranging from mid 80's to well above a hundred. I also run a booster that is installed by the antenna in the attic. So i put a splitter in the incoming line to go to both off air inputs on hd receivers. This worked fine for about a week, and now the signal dropped to about 50 or 60 %, checked the antenna in the attic and it hasn't moved. So is there maybe a special kind of splitter I have to use for this to work correct. The reason I ask when I replace the splitter signal goes back up, for a while and then same problem comes back. Can anybody help me with this, it would be greatly appreciated.
Were you getting a good signal before you installed the amp (booster)? If so remove it and see what happens. Splitting your antenna lead one time should not require an amp unless you have a long run.
splitting ota
I actually thought that I needed the booster to get a good signal,so I took your advise and took the booster of and everything seems to be ok. Signal is a tat lower but it's ok, I never thought the booster would interfear. thanks a bunch :)
Although the amp will increase signal strength, it will also increase noise which could be worse than dealing with a weak signal. If you're not happy with your signal strength, and perhaps begin to experience dropouts during winter months, then you may wish to look for a high quality/very low noise amp.
It looks like you fixed the problem by removing the pre-amp, but to help with the original problem, it may be that you used a splitter with both OR neither ports power passing. Make sure the splitter has only a single current passing leg and that it is going to the power inserter for the pre-amp. A 10db pre-amp would most likely be more than enough for your situation.
Glad it helped.
OTA Success..... and failure too
which tv antenna is good?
