RCA remote and RCA TV
4issquared
24
Hi all, a strange thing happens when I hit the satellite button on my remote control. It changes the TV channel (RCA TV) to channel 2 and then I have to dig out the TV remote to change it back to channel 3. In the set up, I selected channel 3, but it switches to 2. any suggestions are greatly appreciated. :confused:
Hook up a coaxial cable from the back of the satellite box to the back of the tv. Run the "searching for channels option" on the tv menu. The TV will find channel 3 during the search. You can keep the coaxial hooked up or remove it. Once the channel is found it shouldn't go away (unless you repeat the mistake you made originally). :D
dragon002 said:
or if the tv allows you to, go to the menu and delete channel 2
Yup. You can usully set the channel that a specific button goes to on the TV. I have a 10 year old RCA TV that I can tell to go to Channel 90 for S-video when I press Sat on the remote.
problem with pittsburgh fox sports network?
Saying goodbye to a good friend
