Remote Code for Magnavox 15MF605T/17
tv19642001
Just got a new TV for the kitchen, Magnavox 15MF605T/17 LCD. Kitchen is on tuner 2 of a 522, remote is a 6.0 IR/UHF Pro. None of the Magnavox codes work, Power Scan does not work, Magnavox said to call DishNetwork and DishNetwork said to call Magnavox. Any help?
It would not be an issue but a 17-month old little girl is bad enough with 1 remote let alone 2 remotes. :D
Thanks in advance, TMV.
You might try remotecentral.com. They deal with these types of questions often. I suspect though that if no Magnavox/Sylvania /Philips code works you maybe out of luck.
Thanks, Geronimo. If it doesn't work, it doesn't work. More frustrated with the run around with both companies.
Can a PPV be set on a DVR timer?
129 trouble
