Ritz 5g amplifier
$660.00
batzen1981
76
41
Mission Viejo, california
Hi I think the name is my 5g atsc all in one amplifier is Ritz
I noticed when I turn on some led lighting on the same line wall outlet it turns off channels like 7.1 also 62.1 62.2 I believe an is etc.I can remember exactly which amp I have I took off the power supply and it's rated 9v 300ma could sometime point out the website or name is the device I have i remember it was something like Ritz I want to be as a higher amps 9v device to see if that solved the problem
Im pretty sure it's the led lighting drawing all the current because when I switch of the light the channels come back lol
Just wondering what the Max current i can use for this socalled Ritz device
Max current is as much as you want, it makes no difference. VOLTAGE is what makes a difference. So just get another one that's 9 volts, and has the proper connector and you are good.
However, I'm agreeing with the post above me. It's far more likely the led lights are putting out rf interference, and messing with that 5g amp
Reactions: FTA4PA
Yep, I'd bet real money it's the LED light causing your problem. We had the same thing happen when we bought some 'cheapo' 4ft LED shop lights for our garage and basement. They caused notable interference with the TV signal and also killed most weak FM stations on my garage radio. Whether it be poor filtering or badly designed switching power supplies all these things should either required to be fixed or banned for import. :oldmad
Reactions: Foxbat
i just remembered the name kitz kt-700
your right i can use upto 12v, 7-12 Volts DC @ 130ma
so the damm thing can use 12volts
