SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 04/28/2007
digiblur
14,190
4
Louisiana
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 04/28/2007 - 1 change
Uplink Comparison Range: 04/23/2007 05:13P - 04/25/2007 08:15A - (GMT-06:00) Central Time (US & Canada)
113 - SRCOU (NA) removed from Nimiq1/4 91W TP 19 Canada/US beam
Channels in the system: 787
(A) = Available to subscribers
(NA) = Not Available
digiblur,
Elena yesturday reported 2 more channels Removed, besides 113 SRCOU...
Why aren't they showing in your report as well?
digiblur,
Because those 2 channels are still listed in the NIT and SDT tables. They did change descriptor types but they were not removed.
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 04/28/2007 - 4 changes
Uplink Comparison Range: 04/25/2007 08:15A - 04/25/2007 02:53P - (GMT-06:00) Central Time (US & Canada)
804 - CBCHW - Nimiq2/3 82W TP 08 Canada/Non SE US beam changed to Not Available
844 - MVTS1 (NA) removed from Nimiq2/3 82W TP 30 Canada/US beam
845 - MVTS2 (NA) removed from Nimiq2/3 82W TP 30 Canada/US beam
846 - MVTS3 (NA) removed from Nimiq2/3 82W TP 30 Canada/US beam
Channels in the system: 784
Hey guys, first time here so if I'm in the wrong thread plz delete accordingly.
In an area where I cant get Nimiq2/3 - did TP 12559 move sometime in the past 24 hours from Nimiq1/4 to Nimiq2/3 because it went AWOL on me.
TIA!
TIA!
What kind of receiver and dish do you have?
I have an 'elderly' 6000 and an old 24" oval. I'm far enough south that I've never received NIM3 on 91, but get NIM1 with no problem. I spoke with a friend up north who is getting TP 12559 with no problem (he gets both NIM1/3). Since I have been getting this TP until yesterday, coupled with one of the bullitens on Elena's site which stated that TP 24 may be down for a couple of minutes yesterday, well I'm just guessing it may have moved to NIM3.
Well I've read that also and does it actually state that TP24 has moved from NIM1 to NIM3 - I cant quite decipher it? And if it does state such, will the other TPs referenced be moving as well?
nothing moved to Nimiq 3
2 and 3 are at 82
1, 4i, and 4iR are/will be at 91
what i get from it is that stuff is moving from 4i to 4iR with more moves tomorrow (mon) and tue morning
it's all there in that link
/me crosses fingers the footprint doesn't shrink
anyone else deep down south see higher signal levels? pretty sure I'm not seeing things, but I've got 15-20% higher! example, no more fade for me on BBC World (TP7)! :bounce :clap
Needles to say, guess I'm just a tad confused as I thought NIM1 and NIM3 were at 91. So did 4i and now 4iR take the place/position of NIM3? Is the footprint of 4iR still tightly focused towards the northern regions thereby excluding some of us in the far south?
What do you consider the far south? All of the active TP's at 91 have always worked fine here.
digiblur, what size dish do you have? I'm on the left coast tho probably not as far south as you.
I'm using single 20" pan for both 82/91. I've always got everything on 91, but a few were close to the edge. I'm missing a few on 82.
bigger pan or single pan for each helps but i've got limited space on my apt deck so i'm content with what i've got now.
90cm motorized. I used to have an 18inch there when they had the radio channels in the clear but removed it when they scrambled the radio channels.
Meanwhile.. reported by Elena at another forum:
Removed 698 CRKT 6 12.2969 5/6 Nimiq 1 (91) Standard Def
Removed 708 CRKT2 6 12.2969 5/6 Nimiq 1 (91) Standard Def
Removed 712 CRKT* 6 12.2969 5/6 Nimiq 1 (91) Standard Def
The channels might be missing from the receiver but they are still in the tables.
New Expressvu 9200HD Setup
