SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/09/2008
digiblur
14,190
4
Louisiana
Click here for the Uplink Discussion
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/09/2008 - 33 changes
Uplink Comparison Range: 02/04/2008 03:28P - 02/06/2008 11:28A -
468 - ORDER [MPEG2 HD] - EchoStar8 110W TP 19 ConUS beam changed to Available
711 - ISRLI (A) removed from EchoStar9 121W TP 13 ConUS beam
733 - PLSAT (A) removed from EchoStar9 121W TP 13 ConUS beam
736 - ITVN moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
745 - GEOTV (A) removed from EchoStar9 121W TP 13 ConUS beam
814 - GLOBO (A) removed from EchoStar9 121W TP 13 ConUS beam
816 - RTPI (A) removed from EchoStar9 121W TP 13 ConUS beam
902 - GEONW [MPEG2 SD] - Anik F3 118.7W TP 07 ConUS beam changed to Available
902 - GEONW [MPEG2 SD] - EchoStar3 61.5W TP 32 ConUS beam changed to Available
903 - AAGTV [MPEG2 SD] - Anik F3 118.7W TP 07 ConUS beam changed to Available
903 - AAGTV [MPEG2 SD] - EchoStar3 61.5W TP 32 ConUS beam changed to Available
5417 - MT67 (NA) removed from EchoStar5 129W TP 11 ConUS beam
5716 - PLSAT (A) removed from EchoStar9 121W TP 21 ConUS beam
5718 - GEOTV (A) removed from EchoStar9 121W TP 06 ConUS beam
5725 - ISRLI (A) removed from EchoStar9 121W TP 05 ConUS beam
5794 - HDSKD [MPEG4 HD] added to EchoStar5 129W TP 27 ConUS beam (Not Available)
5795 - HDSKD [MPEG4 HD] added to EchoStar5 129W TP 27 ConUS beam (Not Available)
9463 - TEMP [MPEG4 HD] added to EchoStar5 129W TP 11 ConUS beam (Not Available)
9463 - TEMP [MPEG4 HD] added to Echostar12 61.5W TP 09 ConUS beam (Not Available)
9464 - ORDER [MPEG2 HD] - EchoStar8 110W TP 19 ConUS beam changed to Available
9483 - TEMP [MPEG4 HD] added to EchoStar5 129W TP 11 ConUS beam (Not Available)
9483 - TEMP [MPEG4 HD] added to Echostar12 61.5W TP 09 ConUS beam (Not Available)
9484 - TEMP [MPEG4 HD] added to EchoStar5 129W TP 11 ConUS beam (Not Available)
9484 - TEMP [MPEG4 HD] added to Echostar12 61.5W TP 09 ConUS beam (Not Available)
9492 - TEMP [MPEG4 HD] added to EchoStar5 129W TP 11 ConUS beam (Not Available)
9492 - TEMP [MPEG4 HD] added to Echostar12 61.5W TP 09 ConUS beam (Not Available)
9494 - TEMP [MPEG4 HD] added to EchoStar5 129W TP 11 ConUS beam (Not Available)
9494 - TEMP [MPEG4 HD] added to Echostar12 61.5W TP 09 ConUS beam (Not Available)
9637 - PTST1 (A) removed from EchoStar1 148W TP 03 ConUS beam
9680 - DPOP (A) removed from EchoStar2 148W TP 26 ConUS beam
9680 - DPOP (A) removed from Echostar12 61.5W TP 23 ConUS beam
9692 - R-300 (A) removed from Echostar12 61.5W TP 15 ConUS beam
Transponder Changes:
Echostar12 61.5W TP 09 ConUS beam 8PSK added to tables
Channels in the system: 4582
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/09/2008 - 48 changes
Uplink Comparison Range: 02/06/2008 11:28A - 02/07/2008 07:59A -
573 - FPCHN moved from EchoStar2 148W TP 26 ConUS beam to EchoStar1 148W TP 29 ConUS beam (A)
573 - FPCHN moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
578 - BRDGS moved from EchoStar2 148W TP 26 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
578 - BRDGS moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
582 - CCTV4 moved from Echostar12 61.5W TP 15 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
588 - BLUE moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
589 - ANTGO moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 12 ConUS beam (A)
605 - ANTEN moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 12 ConUS beam (A)
622 - APUNJ moved from EchoStar1 148W TP 25 ConUS beam to EchoStar2 148W TP 26 ConUS beam (A)
622 - APUNJ moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 23 ConUS beam (A)
623 - ZGUJ moved from EchoStar1 148W TP 25 ConUS beam to EchoStar2 148W TP 26 ConUS beam (A)
623 - ZGUJ moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 23 ConUS beam (A)
644 - LBC moved from Echostar12 61.5W TP 15 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
645 - ALJAZ moved from Echostar12 61.5W TP 15 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
670 - MBC moved from Echostar12 61.5W TP 15 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
674 - INDMU moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 12 ConUS beam (A)
678 - INDVI moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 12 ConUS beam (A)
778 - NBN moved from EchoStar1 148W TP 19 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A)
778 - NBN moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
911 - ANTRA moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 12 ConUS beam (A)
912 - RYTHM moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
913 - SSPFM moved from EchoStar3 61.5W TP 16 ConUS beam to EchoStar3 61.5W TP 12 ConUS beam (A)
5728 - RAI moved from Echostar12 61.5W TP 15 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
6340 - WKRN moved from EchoStar5 129W TP 13 ConUS beam to EchoStar5 129W TP 10 ConUS beam (A)
6341 - WTVF moved from EchoStar5 129W TP 13 ConUS beam to EchoStar5 129W TP 10 ConUS beam (A)
6342 - WSMV moved from EchoStar5 129W TP 13 ConUS beam to EchoStar5 129W TP 09 ConUS beam (A)
6343 - WZTV moved from EchoStar5 129W TP 13 ConUS beam to EchoStar5 129W TP 09 ConUS beam (A)
9405 - PNTGN moved from Echostar12 61.5W TP 15 ConUS beam to EchoStar3 61.5W TP 27 ConUS beam (A)
9406 - ARTS moved from Echostar12 61.5W TP 15 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
9416 - GSN moved from EchoStar1 148W TP 19 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A)
9416 - GSN moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
9418 - PAEC moved from EchoStar1 148W TP 19 ConUS beam to EchoStar2 148W TP 26 ConUS beam (A)
9418 - PAEC moved from EchoStar3 61.5W TP 29 ConUS beam to Echostar12 61.5W TP 23 ConUS beam (A)
9470 - RAVE moved from Echostar12 61.5W TP 13 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
9471 - EQUTR moved from Echostar12 61.5W TP 13 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
9473 - TRESR moved from Echostar12 61.5W TP 13 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
9474 - ANIMA moved from Echostar12 61.5W TP 13 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
9480 - FILMF moved from Echostar12 61.5W TP 13 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
9481 - MNSTR moved from Echostar12 61.5W TP 13 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
9486 - FAMLY moved from Echostar12 61.5W TP 13 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
9550 - NHLHD moved from EchoStar5 129W TP 27 ConUS beam to EchoStar5 129W TP 08 ConUS beam (A)
9902 - D61.5 moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
Echostar12 61.5W TP 13 ConUS beam 8PSK removed from tables
Echostar12 61.5W TP 15 ConUS beam QPSK removed from tables
EchoStar3 61.5W TP 20 ConUS beam 8PSK added to tables
EchoStar5 129W TP 13 ConUS beam 8PSK removed from tables
EchoStar9 121W TP 09 ConUS beam changed FEC from 2/3 to 3/4
EchoStar9 121W TP 18 ConUS beam changed FEC from 2/3 to 3/4
Trouble replacing 811 with 211.
What's the minimum programming, NON -HD with locals
