Saved OTA list on Dish can't be appended
MorCowbell
9
13
New Mexico
I have Dish with Hopper3. I choose to get local channels OTA and had a "guide list" established at my previous home. Having moved a few miles away, I wanted to update the list by appending a couple new stations via a rescan. As many would know, some stations come in with the UHF/VHF antenna aimed in one direction, while others come in better with a different direction.
Unfortunately, when a scan is done (bringing in 25-30 stations for that particular antenna aim), the dialog screen does not present the established guide list; it presents an empty field to the right that the scanned stations may be selected one by one and added to the empty guide. But because of antenna aim, some stations originally saved are missing, and would have to be retrieved with a different antenna aim. But as I explain, if a 2nd​ scan is done with a different antenna aim, the stations saved from the first scan are lost.
It troubles me that Dish didn't develop software that would allow a user to simply append only 1 or 2 channels to the established list. :mad:
Any thought on this? Has anyone experienced this or heard of this from others?
So, you want the ability to, for example, scan while your antenna is pointed to the east and save those channels to your list. Then, you want to scan again with the antenna pointed to the west, and add some of those channels to the list also while retaining the original channels you added from the east?
How would that work? If you move the antenna and some of your channels are no longer are accessible, there's no point in having them on the list. Unless, you want to re-point the antenna each time you switched from an east channel to a west channel and vice versa.
I suppose you could have one of those remote controlled antenna mast like we had back in the 60's. In that case, I can see your point. I think DISH has just designed the system to fit what the vast majority of users actually have. I'm guessing your situation is a pretty narrow use case scenario. I'm just really happy to be able to have my locals without having to pay the $17 month for them.
I just wish DISH would fix the remote control issue that the last few software downloads screwed up. I use the 54 remote and my Hopper is jumping around from off to on, from live to recording.......................like a Kangaroo.
To Dishstaller, I appreciate your compliment. That was an epic SNL skit !!
To RVvaquero, I appreciate your coments but everything you mention has been considered:
Firstly, I use OTA very rarely - mainly for sporting events.
Secondly, I'm well aware that, since certain channels may scan from one directon while others from another directions, and remembering the difference, for certain stations I will point the antenna in a suitable direction. Some stations come in for almost any direction. In my original list (which has now been discarded), I had about 18 OTA stations and all of them were scanned from the same antenna direction. Even so, the Dish receiver was very particular about ABC (local KOAT 007-01). In the new geographic setting, it gets KOAT easier. Several months ago, due to a contract dispute, CBS (formerly local KRQE on 013-01) was dropped; it hooked up with KOAT as KOATCB (007-04) which is the one station I really needed. But I had to rescan to get it ...
All of ths points to the flaw in Dish's OTA software that prevents scanned stations from simply being appended to a master saved list. The user should be left to manage antenna pointing per OTA station since in many areas (like mine), they don't all come in from the same direction.
As rvvaquero mentioned, you are in a very small population who actually need to move their antenna to receive various TV channels. There are a few reasons why it is not advantageous for Dish to do what you are asking for. First and primary, there are anomalies in the software that can cause issues when you have scanned channels in the mix that have little or no signal. You get error pop ups and cannot watch any channel, OTA or satellite. I have seen these even with my antenna pointed to one direction. Second, you are asking Dish to adapt their software to your needs while the very vast majority don't need that. This is an expense that everyone is going to have to pay for while few gain any advantage.
Have you thought about adding a second antenna so that you are pointing at both directions to fulfill your needs. There are ways to do this and it would fulfill your individual need.
Televes makes an antenna signal combiner that will support two three different antennas pointing towards two different locations, and has filters to drop the signals from the channels that interfere with the 2nd antenna channels. This produces a signal that would contain all your receivable channels in one feed. It would probably cost less than a single antenna on a rotor controlled by a smart box that would relocate the antenna mast towards the TV station you wanted to tune in, plus it's instantaneous, without waiting for the antenna to slew towards its target.
Why Choose the Televes SmartKom?
SmartKom combines filtering, combining, and amplification in one outdoor preamplifier. Its three inputs and 32 programmable digital filters allow installers to select, combine, and level channels from different antenna sources, while the included ASuite app supports both automatic and advanced Bluetooth programming.
Key Benefits
  • Three VHF/UHF antenna inputs
  • 32 programmable digital channel filters
  • Automatic channel scan, filtering, and level balancing
  • Advanced per-channel programming through the ASuite app
  • Bluetooth programming through the included power supply interface
  • Automatic gain control on each filter
  • LTE/5G out-of-band filtering
  • Compatible with HDTV, UHD 4K, and supported ATSC 3.0 signals
  • Configuration retained after power loss
  • 12V, 750mA power supply included
I appreciate your sentiments, Bobby but as a professional programmer for many years, a hallmark of good programing is robustness – anticipating user needs and, where practicable, adding the necessary coding structure. Knowing that Dish must have understood the nuances of antenna directionality on signal strength, it seems that an accommodation could have been made to append direction-dependent stations. Though I haven't seen the code, it would not have taken a lot of effort to make that accommodation. And as to you point about "First and primary, there are anomalies in the software that can cause issues when you have scanned channels in the mix that have little or no signal. You get error pop ups …", if a rogue station causes the issues you described, it can easily be removed.
Another hallmark of good programming is documentation. Dish decided not to release any documentation on the OTA process for users. A key part of such documentation would have been an explanation that when a rescan is performed and new stations are saved, the original OTA list is overwritten. This could have even been done with an onscreen dropdown warning. That would prevent users from finding this out the hard way.
Finally. piggybacking on RVvaquero's comment about the "remote control issue", I should add that I am having a similar issue. Ever since I used the Pairing Wizard to tailor control for my Samsung TV, I find that it sometimes takes not 1, not 2, but 3 presses of the On/Off button (several minutes apart) to finally kill the TV. This is kinda maddening and, as with OTA function, not discussed in any Dish documentation I've seen
I could very well be wrong....it has been a LOT of years but back when I had a 722K it seemed like when you went back to the scan screen that you could just scan again and it would ADD those channels to the previous list or you could delete the previous results and only add the channels from the new scan.
I am not sure about that but I do know that you could manually add additional channels just by entering the actual RF channel number and the older receivers would add the virtual channels to your list
Like I said.....that has been many years ago. Swapped my 722K for a Hopper in 2012.
It does seem like I remember having to delete the existing channels when we did a rescan. Back then our local stations KEPT monkeying around with things and it was non-stop complaints from customers about their channels not coming in. Got so bad that I stopped selling OR installing OTAs....something I had been doing since 1984 so you know it HAD to be pretty bad.
I remember that also on my 722.
Two Hopper 3 DVRs Installation
110/119 Listings Post 129 Transition (Updated 11/01/2026)
