Set up VCR to record off air from H21 receiver.
rmims404
64
I noticed that there is no coax output on the back of the H21 HD receiver. I used this output on an older receiver to feed the video signal to the VCR antenna in coax so I could record OA signals. I only do this once in a while, so I didn't opt for the DVR. Is there any way to do this or am I out of luck? Thanks.
Use the composit (yellow) and analog audio (red/white) outputs to your VCR, usually they all have these inputs, and change your VCR to record the line inputs. If you don't want that approach there are RF modulators you can buy that will take the yellow/red/white connection and convert it to RF/coax.
To record OA signals with a VCR you only need to connect an antenna to it.
Dish Mounting Question
Just Got D*
